0 Members and 427 Guests are viewing this topic.
dole
Yes those are 2000pF 40KV, I used ordinary speaker wire (not to thin) in 2 layers and 2-6 cross turns through center. Then you can induce current in almost anything you put through. If you short circuits nail it will become very hot, I believe adjusting frequency and voltage would be easily to melt it by induction.
@amigo mio: Thank you for right thoughts, I do not understand those “con-artist” but anyway I like to think “If you say that is possible I will make it.. little by little”
So I was just tried to figure out how to transfer those HF HV in something else, useful, and someone mention ferrite, and that’s it. I believe frequency I have is not correct for now, only for low R filament, and of course we need the ground. I just thought it could help thinking en it is far from any claim.
Can we imagine (see) what is in the statement:
“I conclude from this that if a lighting discharge occurs between two clouds, there can be no oscillation, such as would be expected, considering capacity of the clouds. But if the lighting discharge strikes the earth, there is always vibration in the earth, but not in the clouds”
NT
And then we watch Turkey test again  :)
d.
the_big_m_in_ok
@dole
With respect to your drawing on Reply #1592?
1) Would a simple bifilar coil having a tap in the middle and counter-wound turns theoretically work?
2) Is the coil form a hollow metal construction?  The (output?) blue rod is ungrounded?
Interesting circuit, though.  Never saw anything quite like it before.
--Lee
baroutologos
I want to re-publish a txt file allgedly coming from SR that extends his views about the working concept of his apparatus.
http://mazeto.net/index.php/topic,1546.270.html?PHPSESSID=0d0pcj862udlpk8dn7n9lnouj4
Again Google Translator does his stuff, but an average meaning can be conveyed.
xenomorphlabs
Quote from: baroutologos on May 03, 2010, 01:02:45 PM
You said it well :
Quoteallegedly
Because it seems unlikely that he would re-publish
his "famous" post from next- and then insert
points like 1a) (which has not been in his initial post) where he uses the word "maybe".
The other parts are mainly from SR posts subsequent to that.
80% chance that the file has been pasted together by "some guy" with
bits of assumptions.
@dole : Would it be possible to measure the input current into the HV transformer ? You mentioned that you are using a 220V inverter to feed the ignition coil
Is that a commercial type ~150 - 300 Watt ?
dole
Yes commercial ignition coil 10KV 23 mA, + insulation transformer on the input side,
I am sorry I do not have time to do more testing and proper measurements before Wednesday.
I will send the results with more details and new windings then.
d.
