0 Members and 472 Guests are viewing this topic.
jbignes5
Quote from: stivep on February 14, 2013, 05:34:56 PM
imagine that you chapping magnetic filed at 90 degrees
with blades  of fan
would you have variation of electrical properties in primary device?
would that contradict
quoteThe same effect can be created with coil at 90 degrees with square signal on it.
Always gets me into thinking of NMR fundamental orientation of coils.
Wesley
PS: picture below should be named 90 degrees not 80
I'm not quite sure what you are asking here in the first part. The whole reason for using a bifilar coil is to get rid of all counter force associated with solenoid coils. The bemf is actually added to the cemf in the second part of the coil wind. This speeds up the energy raising it's intensity or voltage even further. We have the ability to accelerate the energy and reduce all effects on the primary.
The orientation is a well know aspect to coils and fields. I don't think they put this together like this. Well not many did. I know of a few authors who have gone down this road but to tell you the truth they always end up buried. As more collaborative experimenting is being done on the Internet they can not control every aspect of the direction any more. This is the real power of the Internet. The problem though is who is on the other end of the collaboration. On more then one occasion I have found out that the other end is not who they pretend to be. So in my next phase of research I shall build and post results only with video proof.
I think I got a real good grasp on this project and could even explain how it works via exact experiments to prove these others are very wrong. The only hero worship going on is them worshiping their so called laws. Well how could they be laws if they admit the laws are based on theories. Obviously wrong theories. If a theory is only provable with math then it is not a fact. Math is a man made invention and is as fallible as that man who invented it.
Here is a short video explaining something relevant in my eyes. Pay attention to the voltage references and what it does in her explanation.
http://m.youtube.com/watch?v=sJMtZlPkt6E&feature=g-high-rec
jbignes5
 http://m.youtube.com/watch?v=zreTGaYYq5c&feature=g-high-rec
Here is a chap describing his exciter system. Check the field all around the device shows activity. This exciter field is actually  a leaking system. If one  figured out how to shield the unit from leaking the power would raise up and become unity+ instead of a loss.
This is our problem. We are thinking in terms of the magnetic field and how it self contains itself. The electric field has no limiting rules like magnetics do. Now imagine that system shielded and designed to compress and accelerate the electric potential then release the field in a controlled manner through a matter energy exchange chamber. The field must not touch any other part of the system except where we want to energizing of matter to happen. This is why these systems are currently showing no unity or over unity. It's like trying to fill a tire with air and the tire has huge holes in it.
Ok so back to the crux of the problem. IF ferric cores suck up the magnetic lines then what is inducing current in the secondary when no over saturation occurs of the core? Answer: the Electric field which is not sucked up by ferric core. We have made a grave error in our understanding and I believe that Tesla knew full well of that process. This is why he said on many occasions that if he was using magnetics that he would be doing the same thing as the rest of the electrical community and loosing the same energy to maintain the magnetic fields. Instead of using magnetics he used the electric field to transmit and create movement of current upon a segmented conductor.
I think his disk pump was just a method to try and work out the best way to generate current or power and the respected angles to which you have to bring in energy and exhaust it from the unit. His design also used the 90 degree angle from incoming to outgoing energy flow. Energy in this respect is voltage potential.
One of the strongest examples of transformer action is that we are separating the fields and letting the electric field do it's job. The magnetic field is not used at all in toroidal transformers or any transformer core that is self terminated (circular pathway). Yes a given magnetic flow inside of the transformer can be used to measure the voltage effect because we generally don't measure the voltage field around the wires. We somehow ignore the fact that all electromagnetic fields have distinct sub components. Tesla proved this with a very simple solenoid coil (Tesla coil). Dollard touches on this in his many videos as well.
If transformers worked by magnetic field lines then we should be able to extract power from a pmh with an additional winding forever. This has been tried and failed over and over again. So somehow magically the magnetic lines leap from the iron core into the secondary?? Somehow that is out right unbelievable. What we do know is that iron cores can be permanently energized via the pmh method. So in a toroid core the magnetic field is locked into the core up and until the core saturates. Once saturation happens the magnetic lines are freed of that channel of iron. What I do know is cores to transformers are designed to work within the saturation point. They rarely go beyond that point of saturation because all is losses after that point.
At one time I had a very good idea of the process and tried to relate it to stivep and the others. That a circular core held a constant magnetic field and the wires provided the voltage in a step up direction from a low point or value of voltage to a higher point or value of voltage to squeeze or attract to the highest value of voltage. This moves the magnetic field around in the core. This effect creates lumps of moving magnetic field which I suspect strengthen the voltage field in that area. This creates much larger electric fingers to emit from the surface of the iron core which of course increases the current or inetia from those electric field lines to cross the loops of the secondary. In this case the magnetic field is the innertia so it is kinda like a mass and the electric field lines are the generator lines. The stiffness of those lines is based on the mass of magnetic field inside the core at that point at that time.
stivep
I come in for 1.5 minutes and run out.
jbignes5
I will respond  when I get back
just now I write to let you know that I do respect of ,what you say.
Wesley
jbignes5
Quote from: stivep on February 15, 2013, 11:29:56 PM
jbignes5
Wesley
Thanks. I do respect what you post as well. You have some rather interesting points also. I just wish others had that same respect.
