0 Members and 126 Guests are viewing this topic.
Zeitmaschine
Quote from: tika on March 02, 2013, 08:20:30 AM
It is unfortunate that we are still looking to catch the root cause of the energy gain effect.  Everyone (including me) has his/her interpretation of the phenomenon.  We just know that it is hiding in plain sight.
The only root cause of the energy gain in Bessler's case I can think of (without stretching my imagination too far) is centrifugal force. One falling weight cannot lift an identical second weight so that this lifted second weight then can fall in turn and lift the first weight into its initial state by nothing else than the use of gravity. This is impossible without an additional source of energy.
However, it would be possible by means of gravitational shielding. If only one side of the wheel would be affected by the gravitational field then the Bessler Wheel could rotate forever in perpetual motion, like a water wheel rotates as long as the wheel is submerged only with one half in the flowing water but not with both.
Now someone will tell me that gravitational shielding is not exactly 18th century technology (or is it?). But what about electric (or magnetic) field shielding regarding the Kapanadze device in the 21st century?
Zeitmaschine
Apropos »shielding«:
Kapanadze has clearly visible soldered a sheet of copper onto his tin can. In my humble opinion there can be only two possible reasons for doing this. The first reason would be to hide the wires. But this could be more easily accomplished by wrapping the wires with adhesive tape. The second reason I could think of would be that inside the tin can there is something that has to be shielded very thoroughly.
So what could this be?
Is there a second capacitor or coil in the tin can (in addition to the visible ones) that needs shielding? But shielding from what? From the earth electric field perhaps because copper is not suitable to shield the magnetic field (even less the gravitational field)? And could it be that this shielding is the one component Kapanadze is referring to when saying that he has to make one component himself?
Maybe it's time to search for a proper tin can to do some experiments with it ... 8)
baroutologos
@ above,
a third and forth reason maybe is to be used as a heatsink or do nothing :o
captainkt
@all someone else suggested it makes up the correct weight of copper for 1/4 wave resonance.
Keith
Hoppy
Quote from: Zeitmaschine on March 04, 2013, 09:25:24 AM
Maybe to hide the wires because the tin gets too hot for electrical tape to be practical. It looks so rough a job that I can't see it being for a very technical purpose. TK may have thought it necessary in case anyone were to blow-up the area around the wire entry and see something important  ;D
Taking this idea a step further, maybe he has toroidal transformer inside the tin can and is overloading it in some way to get the OU  ;D ;D
