0 Members and 699 Guests are viewing this topic.
a.king21
Well his patent is complicated because he has to make the device work for 50hz and 220 to 250 volts ac. Some of the circuitry has to take that into account. The basic principle has to be simple and the only logical deduction is high frequency switching which produces a spike wave form and gates energy out of the vacuum. I have done many, many experiments which confirm this. I already have proved the principle to myself many times. What I can not do yet  is loop the system.
Maybe we should ask the EE's on this forum one question at a time from his patents. That may help us to solve the riddle. We also have to remember that the 2004 video is the precursor to the patent. It is still an experiment at that stage.
I for one would be happy just to get a device to heat water - no matter the frequency or voltage.
The compicated stuff after that is just conventional physics.
The biggest clue is that TK worked on a mechanical version with a team at an  ex Soviet factory. The common denominator is the so-called Tesla switch. ie a rapid switching on and off of an inductor in the circuit.
phoneboy
Quote from: Zeitmaschine on March 06, 2013, 09:10:31 PM
But the description in the patent contradicts TK's own statement »it's so simple - you'll laugh«.
High frequency switching with first and second filters, frequency stabilizers and current amplifiers to get a 50Hz output is not exactly that what I would call »simply to laugh«.
»He said, "assume that the water, in its passage into the tank, is converted into something else, which may be taken out of it without using any, or by using very little power."«
Now we assume the tin can is the tank. In this tank there is no electric field. The electric field comes from the outside and enters the tank in a controlled way via the LC circuit which converts the electric field during its passage into something else and that should be an electric current which then generates periodically the magnetic field in the coil of the LC circuit.
One capacitor is inside and one capacitor is outside the tank. Both plates of the outside capacitor and both plates of the inside capacitor make up a (virtual) third capacitor which has one plate outside and one plate inside the shielded tank (tin can), so this capacitor constantly recharges itself due to the difference in the electric fields in and outside the tank but only when the inside of the tank is permanently emptied. That means if the inside of the tank is not emptied (the energy is not consumed by a load) then the capacitor stays charged and the process stops, so there can't be a fatal runaway of the circuit.
Since the earth's electric field is a static one and therefore has no frequency it should not matter whether the pumping frequency in and out of the tank is high or low. Although the higher the frequency the smaller the parts of the circuit can be for the same power rating.
Very nice in theory, but only useful if it really works that way ... :(
Not really, I believe the core component in his device is just what he states, simple.  The concept behind it is key and has been discussed here in another thread.  It's using straight old EM theory no aether or NMR and uses two standard electric/electronic components.
I know you've seen the videos of people dropping magnets down copper tubes, it falls slowly if the tube is continuous but put a slit in it and it falls due gravity, why? Doesn't induction occur in the tube with the slit and if so where does that energy go?  What electronic component is the tube with the slit comparable to, think simple.
a.king21
I came across this video a while back and it didn't mean anything at the time.
http://www.youtube.com/watch?v=NhXV3ca1J6g
Now I believe it is the essence of the TK device. I have captured the relevant still from the vid.
Magluvin
Quote from: phoneboy on March 06, 2013, 10:01:46 PM
When the magnet drops inside the tube, the currents in the 'copper' tube flow around the tube. If it is slit, the path is broken.  The thinner the tube wall, the less lenz will play an effect. If the walls are thick, then even with a slit, there will be lenz currents in small circular motions in the thickness of the copper. ;]
Mags
Farmhand
Quote from: Magluvin on March 07, 2013, 01:52:44 AM
Mags
Spot on Mags, I think it's the eddy currents and the magnetic field they produce which attracts the magnet that caused them, being the eddy current field is opposite.
But I think it also depends on the orientation of the magnet.
I can make a neo magnet float slowly down a flat aluminium plate, in this case one pole of the magnet faces directly the surface of the flat plate (not a tube)
and makes it's eddy current magnet to stick to that way using only one pole.
Cheers
