0 Members and 482 Guests are viewing this topic.
baroutologos
Quote from: Hoppy on March 26, 2013, 11:42:49 AM
Good post from Hel. As he suggests, this is the wrong direction. If TK achieved self-running it was far more likely to have been with some type of transmutation of matter.
i like that. Transmutation of matter, has been always an universal energy giving procedure. The stars give life to Universe by doing that. Nuclear reactors do that also.
If an "free energy" ground breaking device is about to be unleashed, most possibilities go with the "transmutation of matter" in a controllable, safe and easy to do so environment, embeded to a single device.
Cheers,
forest
Quote from: jbignes5 on March 26, 2013, 12:43:47 PM
you guys are missing the main point of all of this. It is the electric field and the way it is vibrated that makes air at our level conductive. Did all of you not read Tesla and his method of transferring real power without much loss at all? There is a way of reducing the anti conductivity of the air and it is only attainable via the electric field and the longitudinal method.
In the case of small devices we would need to stimulate the already established electric field of our planet. That field is longitudinally extending all the way out into space. We know this because there is a magnetic field around our planet. We know you can not have a magnetic field without the e-field as well. This field is already existing around our planet. All we need to do is intensify that field and it will make a connection to the highly charged outer surface of our atmosphere and allow us to tap those charges. This is like poking a hole in the bottom of a lake and letting the water run out of a tube and generating from that water flow. Instead of water we replace the lake with the bounty of charges around our planet. We let it flow towards the planets vacuum and intercept it and use it before it gets to the vacuum and negate it's pull on the charges. It is the ultimate hydro dam. It will flow like water.
Very well said !  ;D Reminds me Tesla article  ::)   Read it again, this is it !
Zeitmaschine
Quote from: Hoppy on March 26, 2013, 02:22:34 PM
Agreed, more like a doctored power meter  ;D Where can these reports be found?
On page 1057 and here: Power meter tricks (09-07-11, 01:50 AM)
Quote from: baroutologos on March 26, 2013, 02:50:20 PM
Not any longer: The Electric Universe theory
»The known characteristics of the interplanetary medium suggest not only that the sun and the planets are electrically charged, but that the sun itself is the focus of a cosmic electric discharge -- the probable source of all its radiant energy.«
Tesla figured that out more than a century ago.
Quote from: forest on March 26, 2013, 03:15:04 PM
Where can I find this Tesla article that talks about »poking a hole in the bottom of a lake«?  I want to read it again.
Hel
Quote from: Zeitmaschine on March 26, 2013, 12:30:45 PM
Then how many watts delivers an antenna with a static voltage difference of 200V to ground? ???
Zero, if there's no charge flow (current). Perhaps millions, if stroke by a lightning. Usually, with
a pointed tip, you can measure few µA if you're lucky.
And what has the surrounding air (and its conductivity) to do with the electric field of the Earth capacitor? Even if there were a vacuum between the two plates (Earth and Sun) the electric field would be still there and there should be an option to tap it. That means, this is not about collecting positively charged ions from the air but tapping the charge of the static electric field itself. Kapanadze calls this »shaking the aether«.
If instead of air we had a perfect vacuum or a perfect dielectric, your aerial would start conducing something only
when reaching the upper plate, of course.
I understand your point... if it's not about using ions but rather "shaking the field" or something similar, then we are
in the realm of EM radiation, or more widely, of changing fields. A "shaken" electric field will be of course a remote
and useable source of energy, which you can get back with an AV plug or resonating antenna depending, but somebody
must DO work to shake it ! It's not much different from a motor driven variable capacitor, you get AC from it but
the motor must do the work and you won't get more, unless you have some external energy also coming into play.
Yes of course I often thought of such an abstract concept of shaking the earth or ionosphere electric field, but to
what point ? How exactly ? I could think of pushing a pendolum which, for some strange reason, when it returns back
it gives me more force than I gave him initially, but that's impossible, unless this act of pushing the pendolum actually
unlocks, primes some external energy already available. I don't see how shaking or stimulating the natural media could
give us something back... I mean, I don't want to exclude this possibility but we lack any credible theory to start with.
Any other way to use the existing field won't give you any free energy. Let's make a simple example. You have a long
insulated antenna pivotted in center which can be made to rotate, so to find itself periodically horizontal and then
vertical w.r.t ground. An alternate current will flow back and forth thru its lenght, caused by electrostatic induction
since it's rotating between the earth-ionosphere E field. If the field and coupling is strong enough, a bulb connected
somewhere in the antenna path will light up - but again, this is not for free, you have to rotate the antenna.
The trick with the alternating electric fields is called a parametric oscillation. Therefore all the coils, capacitors and thyristor/transistors. Although, as it seems, there are several ways to achieve a parametric oscillation, maybe even without semiconductors, like the Testatika.
I don't think a carpenter (Stepanov) connecting his disk saws stumbles over transmutation of matter by chance. And I also don't think there is transmutation of matter involved when an ordinary arc welder makes the power meter running backwards (as reported by some people).
Parametric oscillators are a difficult subject which I don't fully understand, but put it simple it's everytime you have
a dynamically changing parameter of an oscillating system, for example inductance or capacitance. A "charge pump"
made with a rotating (variable) capacitor is a kind of parametric oscillator. Same thing for a system with mechanically
varying inductance. You actually inject energy into the system varying the parameters, but you again have to do
work for that, and you won't get back anything more.
Then, if we want to guess about decaying matter or similar principles inside Kapanadze or other alleged FE devices,
then this is another story (nuclear phisics) and I give up !
forest
Tesla article ? Of course the one and only where he had given his visionary thoughts/tips about future : The Problem of Increasing Human Energy, Century Illustrated Magazine, June 1900
For example : "
In recent experiments I have discovered two novel facts of importance in this connection.  One of these facts is that an electric current is generated in a wire extending from the ground to a great height by the axial, and probably also by the translatory, movement of the earth.  No appreciable current, however, will flow continuously in the wire unless the electricity is allowed to leak out into the air.  Its escape is greatly facilitated by providing at the elevated end of the wire a conducting terminal of great surface, with many sharp edges or points. We are thus enabled to get a continuous supply of electrical energy by merely supporting a wire at a height, but, unfortunately, the amount of electricity which can be so obtained is small.
The second fact which I have ascertained is that the upper air strata are permanently charged with electricity opposite to that of the earth. So, at least, I have interpreted my observations, from which it appears that the earth, with its adjacent insulating and outer conducting envelope, constitutes a highly charged electrical condenser containing, in all probability, a great amount of electrical energy which might be turned to the uses of man, if it were possible to reach with a wire to great altitudes."
but later you will found astonishing chapter ::)
