0 Members and 103 Guests are viewing this topic.
dllabarre
Quote from: Hoppy on March 28, 2013, 04:05:20 AM
I think we agreed that TK's spark gap is just eye candy.
I don't agree Tariel's spark gap is just eye candy.  IF you listened to the Aquarium 1 demo you'd hear the spark gap clicking away but it's not real fast (a lot slower then 50Hz) and it doesn't pulse at a constant rate. It sounds like it changes speeds.
Don
baroutologos
Quote from: verpies on March 27, 2013, 06:32:59 AM
A friend of mine once attempted to build a device based on the Colman principles.
He was semi-successfully, meaning his device sometimes produced unexplained pulses of electric current, but he could not get it to work reliably and repeatedly.  He used a swept FM RF generator between 50 and 160MHz with power around 5W.
I remember an interesting detail out of his experiment - his large-diameter tubes worked better than small-diameter tubes.
hey Verpies,
because i know you and your reasoning / thinking what you say has a special weight for me.
Is that possible, to get your friend with his experience, notes, setups, photos, videos etc over here even in a new thread to display what you experienced back then?
too much to ask?
verpies
Quote from: baroutologos on March 28, 2013, 09:36:14 AM
I would not know where to start :( I have not seen the guy in 18 years.
I remember the frequencies only because I helped him to build the FM oscillator.
a.king21
Quote from: dllabarre on March 28, 2013, 09:13:36 AM
So tell us what is hidden, in a box, in all these Tariel's devices:  Green Box, Demo for Wesley (plastic box on top), Blue Box near lake, Aquarium 1 & 2?
My understanding is the same secret component is hidden in each demo.
Don
The principle is to switch the circuit on and off very quickly.
The device for the switching method  is hidden.
It can be electronic, mechanical, hydro-mechanical, in an oil bath or a mixture of those. Either way we are talking about a Tesla switch.
In Wesley's case he hi-jacked an electronic boiler fast switching device.
TK has two patents. In one he uses a spark gap as a 19th century electronic Mhz switch.
(2004 video and green box.)
In the other he uses a spark gap as an overload protector.  (Aquarium 1 and 2)
There are many ways once the penny drops.
Then you can easily spot  the junk components.
Here's a question for the EE's.
What effect do you get when you wire an iron core trafo in parallel with a HF trafo?
andrea76
Quote from: a.king21 on March 28, 2013, 01:23:52 AM
If people refuse to understand that a spark gap is a mhz circuit gater, able to handle more power than current technology, then it is not my fault.
Bedini tech is simply a watered down version of Tesla.
There are very few mysteries in the TK build for me now.
I used to play with spark gaps, also, without understanding them. Find out how to make an 19th century dc transformer work first then you'll see that out understanding of Tesla's circuits is nowhere without that info.
So you don't actually need a spark gap.
the spark gap is not "primary source".it is only a static discharge circuit.like grounding wire.Bob Boyce says that "energy" appears in the electric wire net of the house  when the device is in operation.the first device of TK is rotating shaft coupled with an alternator for producing 50 hz sineweave.why? because the "energy" has a high frequency component  which does not works with an inductive loads.
http://www.youtube.com/watch?v=1l6TGpe0uKs
