0 Members and 436 Guests are viewing this topic.
Grumage
Hello to all,
Taking great risk of sounding stupid here, actually no, my age does that for me  :).
I wonder if I and maybe others have misinterpreted the TK device as an HORIZONTAL Tesla coil. I have been aplying the HT to what I would now call the secondary. This prompted by many of the schematics that are out there. I wonder if the HT should be applied to the Large 6/7 turn coil, Tesla coil primary? Apologies if this has been mentioned before, I personally was not inclined to read the entire thread's 1000 and more pages!!  After watching    http://youtu.be/r4dP1IF70a8   Courtesy Ganzha. And recent post's of foil secondaries. I really do feel we are getting close.
On a different note, mainly for Zeitmaschine, I have spent the last two days, not wholely but nearly!! testing the Parametric generator.
http://bd.patent.su/2386000-2386999/pat/servl/servlet92b8.html
Using a very large inductor and Motor run capacitors I was able to get a resonant frequency of 14 HZ. I replaced the SCR's with small automotive relays driven by a couple of PWM's wired in alternate mode.
Though not an Eureka moment there were times when the applied voltage on C1 would last for well over 30 seconds, diminishing very slowly.
Whether it is worth persuing further I do not know but one thing I did notice that by manually varying the M/S ratio between the two relays I could juggle the voltage up!!
Any way having been restimulated by Ganzha's earlier post and a visit to The old scientist's website it's a case of HT for ME!!
Cheers Grum.
PS Just re read my post, to clarify, IT IS  in my opinion a horizontal Tesla coil. With attached secondaries.G.
x_name41
Quote from: Ganzha on March 28, 2013, 07:16:43 PM
there is simple Tesla s experiment with Free Energy
Maybe a Kapanadze is too simple for  us?
yes, here is the correct variant and truth!, but did you know in one article Ralph Ring used the word "Resonance" and "open circuit or system" and for this reason I saw the that these things (are his projects with Otis Carr and those of Tariel Kapanadze) are very close somehow
jbignes5
Yeah from what I am getting from researching Tesla yet again is that the rays or particles will stream out of the end of the Tesla coil. This was why he had a copper can at the end and the wires inside of the can are merely connections to the can. The load connects to the can as well and goes through the load to ground.
I suspect that inside of the blue box in the backyard video in 2004 there was a magnet. Probably not enough to get an effective blowing out of the spark gap but good enough to do what he wanted.
It seems it is a straight up replication of a Tesla concept of radiant energy. The only things that are different are the inverter and transistors. Tesla had diode tubes so he could rectify what he needed for the DC component to loop the device.
Zeitmaschine
Quote from: Grumage on March 29, 2013, 05:10:23 PM
Which of them? The TK devices are all different in their appearance.
Within a Faraday cage? My feeling says the Faraday cage is the most important part of the TK device. The equations in the above patent might be correct but the parametric generator can only work if it has the chance to draw (suck) energy from the environment. This is like a still-standing water wheel because the wheel can't reach the water in the river.
Anyway, since I haven't had much time lately doing a lot of real experiments, I prefer the method of throwing some theories into the forum and then waiting for the results to come in. ;D
stivep
evening of Friday + two nights no sleep.
for the good reason
Do not worry
be happy :)
Do not worry
be happy :)
You think Wesley  is a flip?
you should know me by now :)
Wesley
