0 Members and 468 Guests are viewing this topic.
x_name41
Quote from: stivep on March 29, 2013, 07:20:18 PM
evening of Friday + two nights no sleep.
for the good reason
Do not worry
be happy :)
Do not worry
be happy :)
You think Wesley  is a flip?
you should know me by now :)
Wesley
stivep, i also have not slept several nights since I found these things, simply my excitement was great after re-reading by the several times of that material out there :)
Farmhand
Quote from: Ganzha on March 28, 2013, 07:16:43 PM
there is simple Tesla s experiment with Free Energy
http://youtu.be/r4dP1IF70a8
Maybe a Kapanadze is too simple for  us? ;D
For those of us that don't speak Russian or whatever Language is used in the video.
What is it in the video that shows free energy ?
Surely the Tesla coil is powered. Unless the load power exceeds the input power to the setup I see nothing out of the ordinary.
Where are the measurements shown ?
Cheers
jbignes5
Quote from: Zeitmaschine on March 29, 2013, 07:00:25 PM
Which of them? The TK devices are all different in their appearance.
Within a Faraday cage? My feeling says the Faraday cage is the most important part of the TK device. The equations in the above patent might be correct but the parametric generator can only work if it has the chance to draw (suck) energy from the environment. This is like a still-standing water wheel because the wheel can't reach the water in the river.
Anyway, since I haven't had much time lately doing a lot of real experiments, I prefer the method of throwing some theories into the forum and then waiting for the results to come in. ;D
All of them are replications of different facets of Tesla devices. Each one TK did can be directly correlated to each device in Tesla's radiant series.
I don't think the copper was a faraday cage because even metal does not shield the radiant wave if you read the link I provided. But it does create huge amounts of current in a copper sheet. Which is in the 2004 video of his back yard device. Not the clear one, the one with a blue box and the larger coil over the thinner coil. The inside one in his house had the copper can and the outside one had a copper box that housed the transformer and diodes. The copper housing around the transformer had perforations as well which wouldn't have made a good screen against this ray.
In the video when they lift the whole device and components they keep this encased transformer in the target of the coil which was horizontal as well. And it was encased in a cloth like housing. Maybe polyester or something like that.
The turkey video was another replication of his standing coil system but in each metal housing was the spark gap with magnetic quenching. The coils towers on top of each bifilar pancake coil with antenna<-- ie the wire making the spark gap over each tower is a known aspect of Tesla design. The bifilar coil was housed in between two wooden plates on the bottom of each tower and the harness coils were slipped over the antenna/spark gap. The caps were for each harness coil and were pulsed by the spark gaps over the towers. These were not connected in any way. I mean the harness coils and the antennas. Radiant energy flowed out of the antenna at right angles of the straight wires from the bifilar pancakes under each tower. Since the bifilar has limited self induction the spark was accelerated by this and intensified the radiant pulse which should be shorted to ground after the bifilar coil. It follows Tesla's experiments to a "T".
The fish tank experiment I'm still working on.
The warehouse video is of a one wire motor excited by the transformer I have been showing, termed by me as the "special" transformer. One side is hooked to one terminal of the transformer inside of the metal base and only one wire delivers power to the disk motor tesla designed then connected to the metal of the base box as the plate.
All of these examples and devices that TK showed are covered in the links I provided at tfc books: http://www.tfcbooks.com/tesla/1892-02-03.htm
The other links I provided were to let you know what radiant energy is and how he discovered it and subsequently utilized it.
The picture below is part of the turkey video that was outside in the tent.
x_name41
Tariel Kapanadze does not use a flat bifilar pancake coil and standard schematic diagram an ordinary Tesla transformer that lies under the road and over road in the internet! He uses resonance power supply of the Tesla transformer and from this power supply comes the output power such as into account the specificities of the system or of the circuit (one wire transmission and electrostatic induction method of Nikola Tesla)
jbignes5
Quote from: x_name41 on March 29, 2013, 08:45:38 PM
Look closely at the turkey videos. That version used the flat bifilar coils below the towers. They were sandwiched in between the bottom round wooden bases.
