0 Members and 183 Guests are viewing this topic.
jbignes5
There is nothing to confirm. It was a JOKE for April fools. Do you not get this?
It is not real. None of it is real except the guy who made it.
Please look up Dr. lirpra Sloof and you will see. Also look up April fools and you will understand. Hopefully.
Zeitmaschine
The 1st of April? There are a lot of 1st of Aprils each year, I'm afraid. >:( 8)
So the investigation goes: A differential circuit breaker contains apparently a ferrite toroid that acts as a differential coil (hence the name). That means only the difference between two (or more) currents creates a magnetic field in that coil. Therefore the interesting part of this is the question what could happen when there is a three-phase capacitor (or three single capacitors) connected to that differential coil? Especially if one pole of the three-phase capacitor is connected to N (neutral, ground) as seen in the Stepanov demonstration? Could this create a special resonance? Or could this coil generate the gate voltage for a couple of thyristors so the whole setup goes into resonance with the ground connection?
And as a strange coincidence there are two differential coils (filters) visible in the center part of the Steven Marks TPU right next to the nice two capacitors. How can that be? Here are the suggestions: The differential coils are there just for decoration, they are there for filtering the radio interferences or they are there to make the device work.
I love strange coincidences ... (even on 2nd of April) ;D
And yes, don't forget the Faraday cage.
Poit
One thousand, one hundred and eleven pages.... for what? what does anyone have to show for it? where is the blue prints to build this "5KW" free energy device?
jbignes5
Quote from: Zeitmaschine on April 02, 2013, 09:20:39 PM
I had already posed the answer to that tpu.
Answer this riddle. If iron channels the magnetic field of a coil then what is acting on the large external coil? What other field is left after the magnetic field is channeled or locked away in the core of the two smaller cores?
Your answer is exactly what I have been proposing for any device posed in this thread.
Again if the magnetic field is sucked into the core then what field is left?
Have you ever heard of iron coated copper wire? Would there be a magnetic field around such wire?
x_name41
jbignew bjejinski please do not be call ye so rashly, since the user lasersaber has such a book which at all not is located on the Internet! this book is written by Lipra Sloof and there has a whole chapter about the nature of the water.
