0 Members and 74 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on April 17, 2013, 03:45:45 PM
  Maybe the BS is not in the can...
Then BS is everywhere but in the can. 8)
Sirius Documentary - 2013 Theatrical Trailer
So I'm waiting for our Space Family to bring FE along. Last resort if nothing helps.
Hoppy
Quote from: Zeitmaschine on April 17, 2013, 05:45:01 PM
I thought we had moved onto horse shit a few days ago  ;D
NickZ
  Or the BS has been in our minds.
  I'm also waiting for our space brothers to give us helping hand. I know they are out there (here too), and there was a reason that they could not do so, before. This has changed...
  Zeitmaschine:  I feel that you are a realist, as myself. But, money talks and Bs walks. At least thats how it been up to now.  But, patients is a virtue, one that I'm still working on.
  Would love to get into more experimenting, as Grum suggests. More in the sense of more output power. I still have not resolved the how or why the yokes can kick into higher resonance, when they feel like it, without my being able to control this, yet.
  Although I'm a talker, I've got my hands full also, 24/7 on 100% focus to resolve this FE issue. At least for myself, and anyone interested. Let's not give up, Heaven forbid!
stivep
http://www.youtube.com/watch?v=_e3RpsEZE14
Free Energy Генератор Свободной энергии с самозапиткой TUNGUS TS-TK
Tungus have made  Replication of Tariel Kapanadze without battery and without  ground
It contains famous yoke.
the only that paps to my mind is that that again  synchronization of resonance response is  due to properties of ferrite.
anyhow schematic is there
for you to replicate it/
Someone would ask what is the basis for that device to work?
Well NMR I assume.
with transmutation on going to the yoke.
That what is important to know is that  device works  and schematic is   ready for you to work with.
If than device is replicable TK is done for good
But there is even more than  that.
TK might come with his secrets out as he has no choice.
Let's see........
Verpies and others thank you very much for a lot   of education that  took place here.
For me the most important is   to know what is the basis of its work.
The guy does not explain   how to make it.
He  shows that ground is needed only to  "more bright light"- quote.
After today's session with Arunas and my friend John the conclusion is that istead of any additional dope  that would activate alpha particles 50MeV there is  ferrite that has it in it.
That would match SR device as well
QuoteAnd this is  material from Arunas:
: http://peswiki.com/index.php/OS:Doug_Konzen_%28Konehead%29_on_Self-Looped_Generators
"https://sites.google.com/site/alternativeworldenergy/shorting-coils-circuits
LOOK at the third circuit in the link [directly] above, for a "two stage" output circuit...the first circuit is something to find sine wave peaks, the 2nd circuit is a coil-shorting at peak circuit that also has pulse width adjust, too.
Here is simple shorting-coils-at-peaks circuit - this shows how TO FILL caps: https://sites.google.com/site/alternativeworldenergy/upright-alternator-circuits
LOOK at the diode-plug circuit in the diagram above. This should make perfect logical sense to you, and anyone else, if you follow the circuit. Note that the generator coil only FILLS CAPS. That's all it does. It NEVER sees the load. This eliminates Lenz-law lugging to a generator, for example, whenever a load is put on the system. THE ONLY lugging will occur when CAPS FILL UP...So fill caps via a method that does not lug the system when filling caps!!
One method is to SHORT COILS AT PEAKS, which fills up caps so fast you wouldn't believe, and outputting caps to load is simple as pie. Just use the two-stage or "diode plug" circuit. Another method to fill caps without lugging is the ROPMEROUK type Muller generator with magnets behind coil-cores. Another is the THANE type generators.
Have some fun, eh, on that radio show - "lump resistive load" without any sort of two-stage or diode plug cap-discharge output is how they HIDE OU! Whether intentionally or not...
[Remember that] Eugene Mallove was murdered the day after he was on Coast to Coast, so don't mention anything that might upset them, whoever they might be.
ciao
Konehead "
Wesley
verpies
Quote from: NickZ on April 17, 2013, 02:15:02 PM
You are comparing apples with pears. Your betavoltaic example, which were mostly using low voltage galvanics as the electricity production means, and/or Hydrogen Isotopes don't relate to gamma decay.
No, I am illustrating that nuclear radiation can be converted to electric current with well known methods and some novel ones too.
Of course you are correct that Betavoltaics does nothing for gamma conversion - it works only with beta particles (not necessarily emitted by tritium) - that's the reason it is called BETAvoltaics.
It is obvious that alpha, beta and gamma all require different methods of conversion to electric current, but that's beside the point.  This conversion process is not the source of energy, nor anything new nor unusual.
Only the artificial stimulation of nuclear radiation is an anomaly.
Nor did they produce any real useful current output, anything like 10kw, or so.
That's only a matter of scaling it up or using other methods for conversion.
As far as I know or have seen the Edison Battery idea has not been replicated to produce the 10kw, by anyone else, lately. Have the Colman tests been replicated?
There is anecdotal evidence of that.  On this forum only Wesley have done that and Grumage might be getting close.
How can you say that X-rays emitted from Crt tubes are non-harmful, how can you be so sure. First time I've heard of this. People have died from exposure x-ray radiation, although possibly not from TV sets.
Same thing with cell phones? Not harmful? It may take years before any real conclusive evidences are obtained.
I never wrote that they are not harmful when they are uncontained.
I think that all EM radiation, beta, alpha and neutrons are harmful when they are not contained.
My point was not about their harmfulness but about the possibility of their conversion to electric current.
When one bangs a ferrite coil with extreme HV, combined with short wave emissions, a broadband of radiations can be obtained. Without an means to control it. How can anyone really know what the outcome will be.  Will you be the one to test this... just put Al foil over it.  Tk has foiled his walls, must be for a reason.  The diagram presented previously showed that foil will not stop certain types of radiation, that only lead would.
Aluminum foil will protect the operator only from alphas and betas.  Lead will stop gammas but it will convert betas to Xrays which is not a good thing.  So far we don't even know which one of them is emitted out of the activated Colman tube.
I don't know if this is correct, but, who will be the one to find out. Wesley feels that this is safer than his successful yoke coil experiments, that he was scared to follow up on.
I don't think it is safer.  In fact I don't think those devices are that much different.
Quote from: NickZ on April 17, 2013, 02:15:02 PMa.king has also mentioned no such radiation poisoning related disorders noticed by his group.
Maybe it was well shielded already.
Quote from: NickZ on April 17, 2013, 02:15:02 PMBut, to relate Alfa/Beta/Gamma radiation experiment with what TK was doing, is stretching it a bit.
Why? It can be done inadvertently without even considering nuclear decay. TK might have put a copper tube in some orthogonal primary windings and strong pulses appeared on the secondary.   He got sick so he put it in a tin can and problem solved.
Quote from: NickZ on April 17, 2013, 02:15:02 PMHe was stating that the energy comes from the ambient, not a destructive and possibly dangerous radioactive decay process.
It might have looked to him that way, but all that time he was unknowingly converting mater to energy.
And even if he knew the truth, would he tell us this and allow us to replicate his device?
I don't know, that's no longer science - that's psychology and sociology.
Quote from: NickZ on April 17, 2013, 02:15:02 PMIf he was wrong, why can't ANYONE replicate ANY of his experiments using only similar old junk parts, like he showed, just to prove the point???
Perhaps because all those who have tried believed in "energy from the ambient" and ignored the possibility that  the the energy may originate from matter conversion, e.g that unslotted copper tube that Hoppy mentioned.
If TK's devices are based on NMR then they would be notoriously hard to tune, just like the famous Yoke device. This would discourage most replication attempts, unless one knew what to look for.
Quote from: NickZ on April 17, 2013, 02:15:02 PMHe was not needing to use two signal generators,
Only one generator/oscillator is needed for NMR stimulation.  Two of them make it easier but are optional.  The LF gen can always be substituted with 50Hz mains transformer and aided by magnets.
Quote from: NickZ on April 17, 2013, 02:15:02 PMspecial frequencies,
...but we don't know the waveforms in TK's devices because he does not allow anyone to connect an oscilloscope.  He even says that connecting a scope or SA would "reveal his secret" which is an indication that the waveforms are part of the secret (or that they would expose the Modus Operandi of his devices).
Quote from: NickZ on April 17, 2013, 02:15:02 PMand "special ferrite cores".
He might have found a way to stimulate ordinary materials such as brass and copper.
Quote from: NickZ on April 17, 2013, 02:15:02 PMOnly an old dead car battery/inverter set up, or just a regular 9v battery, to kick start what appeared to be just regular air coils combined with an ordinary air gap. The trick as Zeit has mentioned, may be in the wiring, as also repeatedly mentioned by SM, on his many TPU devices. This is what I feel we still need to focus on.
A short and strong nanopulse from a spark gap (or DSRD) is just what is needed to elicit NMR in common materials without the regard for magnetic flux density and frequency tunning, because a short pulse already contains many frequencies according to Mr. Fourier.  I call it the "gunshot approach" to NMR.
Quote from: NickZ on April 17, 2013, 02:15:02 PMWe are deviating from the TK tests into unknown and dangerous areas, even though there may be some similarities.
The word "deviate" suggest that there is some right path that needs to be followed, but frankly we don't know what the right path is.
Anything that fits into that tin can could be this "right path".
For example, the experiments that Grumage is doing lately could easily fit into a tin can like that.
Quote from: NickZ on April 17, 2013, 02:15:02 PMThe ideas of only fake devices to fool people into advancing money, has stopped us from finding the true effect generation and working causes of the Kapanadze experiments.
These ideas also need to be considered to maintain the rigour, but frankly we are not certain how TK devices work and if they are fake or not. Wattsup provided pretty convincing evidence that one device was fake but it was not an inconvertible proof.
The "energy from the ambient" M.O. has been discussed for years and has not born fruit.
Isn't it time to give the "energy from matter" a chance, as long as it fits in the tin can and the junk around it?
