0 Members and 28 Guests are viewing this topic.
anandml
HendershotMarkIII
No Option to upload an "Avatar"
New member.
I have already gone to "Profile" -> "Forum Profile" and clicked on "Change Profile".  "No Avatar" is selected but no option to upload new pic.
Anyone? :P
verpies
Quote from: anandml on May 16, 2013, 11:18:04 PM
JNaudin done this setup and he replicated successfully  but he failed to make a self run.
http://jnaudin.free.fr/gegene/gegene13en.htm
Has JNaudin done what Ghanza and T-1000 are proposing ?
Namely, putting bifilar wound (in bucking mode) coil inside a HF inductive heater coil (perpendicularly or parallelly).
Quote from: T-1000 on May 16, 2013, 08:16:34 AM
...you need induction cooker type circuit connected to your yoke then apply resonance in series to air coil. It will be OK only when will start to heat up wrench inside of air coil. Next, you need to modulate that magnetic field with choke inside of air coil and see what output you get in coil on top of air coil.
Quote from: Ganzha on May 16, 2013, 08:31:04 PM
and keep in mind this
Regarding Ganzha's diagram - Normally two halves of bifilarly wound coil cancel their inductance when they are connected in bucking mode (there are always two ways to connect a bifilar coil, see here).  In other words, they behave just like a straight piece of wire (especially helical coils, a.k.a. solenoids).
Also, a solenoidal inductive heater coil will not induce directly any net current in such bifilar coils, because the HF EMF in each bifilar-half will cancel out (that's the essence of bucking mode). On the diagram below this means that the HF AC from the outer coil will not directly induce a net EMF in the inner bifilar bucking coil.
However the outer inductive heater coil will have an influence on the matter that the inner bifilar coil's windings are made out of and it will influence any shields or cores that are inside it (even if it is rotated 90deg.)
T-1000 suggests that this influence will be anomalous and will lead to unexpected release of energy (especially when the core is saturated as manifested by rapid heating).
That arrangement and saturation of the core resembles the Michael Meyer patent.
zcsaba77
Quote from: verpies on May 17, 2013, 02:39:05 AM
Also, a solenoidal inductive heater coil will not induce any net current in such bifilar coils, because the HF EMF in each bifilar-half will cancel out (that's the essence of bucking mode).
Hi Verpies
Maybe my teories wrong, but 'Bucking' (CW-CCW) conected coil have meaning, but NOT in 1:1 ratio, somewhere I read from Tesla's patent he us 1:4 or 4:1, for me not was clear that was lenght of wire or ratio beetween two turns, not clear for me what magnetic/inductiv/electric effect goes in coil/wire when meet oposite waves/inductance or magnetic force, and in right moment came back pulling-pushing in whole coil system, will goes easy like when u swing your child, in right moment just need little push, not?
regards Csaba
verpies
Yes, of course.
Any kind of asymmetry in the bucking bifilar coil will prevent complete cancellation.
1:4 bucking coil is not symmetric.
