0 Members and 1845 Guests are viewing this topic.
sparks
In order to cause an avalanche, primary electrons have to cause more than one secondary electron emissions from ionized atoms, on average.Do you think that the collective kinetic energy of the secondary electrons is greater than the primary electron's ?  If "yes" - why?
  Yes because the secondary electrons are accelerated by the electric field whereas when they were bound they were not.  Ionization is a simple conversion of electron mass.  Any change in the electron mass is accompanied by radiation.  If this radiation is of a wavelength that results in the optimum wavelength for ionization of "receiver" atoms then the first incident photon invested can result in  avalanche ionization.   This creates a large number of free electrons that respond to the accelerating electric field between charged capacitor plates.   If your capacitor plates have an insulated cathode and an uninsulated anode then the electrons will bombard the anode.  The first electrons to arrive would fill the holes in the anode which would collapse the accelerating field.  The electrons still continue to arrive due to their inertia and their electric field displaces electrons in the anode which results in a current pulse traveling through the wire attached to the anode.  This current pulse is in the same direction as the charging current.   The transient then can be filtered or damped in an rlc where l is the load to be driven.  The problem with this is there is anode heating due to the deacceleration of the fast electrons within the metal of the anode.    This is why an insulated anode is better.  The electric field of the electrons will pass through the dielectric but not the actual electrons.  The space charge builds up and insulates the anode but the current pulse is still inititiated in the output circuits.  The system is then relaxed.  The space electrons now find themselves attracted to the ions and migrate back and become atoms again.  As the electrons drop into valence orbitals a secondary photon event is produced and results in a glow zone. This is all derived from work done by Crookes.  He would put two pieces of metal in a bottle.  Hook the two pieces of metal up to a high voltage supply then evacuate the bottles to varying degrees and observe and record the effects.  Tesla found out about this science directly from Crookes and being the applied science genious he was went to work using the first particle accelerators to grace the Earth.
  Plants use magnesium as the gain medium.  Ultraviolet light from the sun cause ionization of the magnesium atoms.  This free electron is a pretty fast electron.  The kinetic energy of a free electron is in excess of the energy needed to ionize the electron.  It is so simple.  The electron had kinetic energy when it was bound so why would it just decide to loose this kinetic energy when it was unbound?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
baroutologos
Quote from: sparks on June 11, 2013, 11:27:17 AM
hahaha... I have the same thoughts more or less regarding the potential of using the electric field (instead of magnetic field) for energy generation. Almost a week ago i have PM verpies with a "concept" of such hypothetical device for evaluation and point out the wrong thinking of course.
In general, i was thinking, as you sparks say, an Insulated capacitor plates of tremendous E-field, between them, and on one hand a spiked lower voltage cathode (heated or not) creating a corrona effect or in hard vaccum etc that will release electrons between the plates that will naturally be accelarated by the E-field and on the other hand a plate or grid that will harvest them. In the mean space the accelarated electrons to be slowed down by inductive means transfering energy to a coil. (in resonance or not)
Of course, after making an preliminary research to get a basic understanding of the values involved have found that capacitance of plates of say 10cm x 10cm spaced few cm away is redicoulusly low (10-20 pf) and the spacing of few cm do not allow the deployment of any inductive means... let aside the whole concept does not address the question of where the energy should be coming from... its like managing to harvest energy from magnets.
cheers,
verpies
The rest mass?
Do you mean electron's relativistic mass due to motion or its rest mass?
Are you implying that the voltage across the capacitor (accelerating electric field) remains unaffected before the first electron arrives at the anode?
elementSix
THIS is for every One That I promised I would tell them how I achieved the Intensifying effect of feeble Input energy.   I  am very sorry it took so long, but My partner in crime, got scarred off, He said it was because it actually worked and he didn't want to cause problems for his family.  He thought I was Full of shit when I asked him to help me in this work.  Then we got large spikes of energy while playing with 12V power supply that ran into another small transformer.  The outputs of that transformer had one wire going to a round disc from a hard drive and the other wire was connected to an electrolytic capacitor that was grounded on its other terminal.  On the 12 Volt input I had the negative 12V wire as a spark gap and the other I just connected it directly to the other transformer.  But I had to use a neo magnet to create the arc.  Without the magnetic quench it would not create a spark gap, it was a small wall socket type of transformer I took apart and connect up a Bridge rectifier.  When I would get a good spark the wire from the ground connection and the opposite wire that was connected to an elevated terminal would get a large current spike that lasted about a second.  It was at a certain resonant frequency.  So I knew then that everything Tariel said was true.  The Tesla patent that I went off of and am now updating is Patent 685,953.  METHOD OF INTENSIFYING EFFECTS TRANSMITTED THROUGH NATURAL MEDIA.  There are 4 patents that pertain to this subject.  The device uses two pates.  Tesla use steel plates for his device.  The plates can be both in the ground or both in the air, they can also have one in the ground and one in the air.   Tariel Kapandaze Used all three setups I believe.   I will try to borrow a camera in the next month and show everyone what they need to do.  But If I can figure it out, then you guys certainly can.  I will need help in creating a Circuit to adjust the input for Resonance.  Without it, the device will not work very well.  The spinning cylinder that tesla used can be replaced with transistors and a spark gap.  The gap I believe creates the frequency's for it to all work, but I could be wrong.  I will put the links to the patents below and read them.  Don't just skim thru them.  I would also recommend reading Tesla's Colorado notes or that interview that I posted the other day.  Its on the page also, but its toward the bottom of the web page.   If anyone can sujest what circuit I should use as an input, I would appreciate it.  I was thinking of using a Ramp Generator or a Phase Locked Loop.  Just a thought.   I wish you luck..  I do need help, I am not a circuit expert.  Thanks and Peace.
http://www.teslauniverse.com/nikola-tesla-patents-685,953-intensifying-transmitted-effects
http://www.teslauniverse.com/nikola-tesla-patents-685,954-natural-media-transmitting
http://www.teslauniverse.com/nikola-tesla-patents-685,955-utilizing-transmitted-effects
http://www.teslauniverse.com/nikola-tesla-patents-685,956-natural-media-transmitting
Сергей В.
Всем здрасте !!
As i said couple a months ago there was started Energetic Revolution on this planet. As times going there will be as much as possible OU devices for humankind. This will push Massive Global change in all areas and bring this planet on the new basis in social organization, science, politics economy and all discipline of human mind activity. This is a process which can't be stopped because is controlling by our Ancestors on all 7 levels of Physical Reality in our part of Universe.
So in Brasilia Dr.Antonio Carlos M. de Queiroz has made significant breakthrough in understanding and spreading Tesla Technologies in a right time. Of course with some help of Tariel Kapanadze. There are two finished OU devices one 6.6 kWatts and another 250KWatts. Braisilia like one of Free County and a Leader in South America will have very big influence on other countries in the world first in energetic and than in all other aspects.
You should watch these video on Portuguese language about new Brasilian OU devices.
http://www.youtube.com/watch?v=iRSP7h73u-Q
http://www.youtube.com/watch?v=2nxdiFxgcvM
The Brasilian Free Energy site is: http://energiauniversal.eco.br
And of course you should inform yourself about Dr. Antônio Carlos M. de Queiroz - The Pioneer of Tesla Technologies in South America.
Short Info from his Home Page
Dr. Antônio Carlos Moreirão de Queiroz is Associate Professor at COPPE, Electrical Engineering Program, and at the Electronic and Computer Engineering Department of the Polytechnic School, Federal University of Rio de Janeiro (UFRJ). He obtained the B. Sc in electronic engineering (1979) from UFRJ, and the M. Sc. (1984) and D. Sc. (1990), in electrical engineering, from COPPE/UFRJ. His current interests are in circuit theory, switched-current filter structures and analysis methods, techniques for the design of high-frequency continuous-time filters, approximation techniques for general-purpose filters, analysis and simulation techniques for electronic circuits, radiofrequency circuits, and history of science.
One of the Best Site about Nikolai Tesla Technologies. Many interesting articles, programs and important informations with great number of experiments and oscillogram proofs.
You shoud have upper level of Mathematics and Physics knowledge to keep atention on his thoughts and ideas. I recomend to all folowers of Tesla Tecnhnologies.
http://www.coe.ufrj.br/~acmq/index.html
Technical documentation by Dr. Antônio Carlos Moreirão de Queiroz
http://www.coe.ufrj.br/~acmq/papers/papers.html
