0 Members and 326 Guests are viewing this topic.
captainkt
@zeitmashine, it might look strange by convention but what if somehow the voltage backfeeds to the isolation transformer and takes the load off. Are we looking too deep with 50 HZ oscillators when we can get 50HZ from grid and mod it. Kapanadze 2004 vid contains similar components as this Brazil circuit, (transformer rectifier and inverter)
Keith
verpies
Quote from: elementSix on June 12, 2013, 08:30:03 PM
Can you help me out.  I would greatly appreciate your expertise.  If you could look over those patents from Tesla I posted on the previous page and guide or point me in the right direction to build an up to date version of his circuit controller.  The spinning Cylinders that he uses to create the inter-mitten arcs that go into the primary Inductance.  Anyone can put their two cents in and I would really appreciate the help with the Transistor circuit.
I am still trying to digest that patent.
sparks
Quote from: shiba on June 13, 2013, 04:29:01 AM
Hi again,
What kind of medium do you have inside your capacitor (air, solid dielectric, vacuum) ? More precisely, what do you know about this medium characteristics, its model, how to estimate its status, how stable is it? What is the maximum electric field strength for this medium? What is the electric field strength in the space between the plates? What about stability and  repeatability of boundary conditions and your plates material?
Please, see my previous posts about ground state of hydrogen atom as a consequence of the uncertainty principle:
« Reply #17703 on: May 22, 2013, 11:06:04 PM »
« Reply #17704 on: May 22, 2013, 11:24:53 PM »
« Reply #17705 on: May 22, 2013, 11:41:03 PM »
This elementary  non-relativistic calculation derives kinetic energy of the ground state  (0 angular momentum state) from the uncertainty principle. It gives correct result for the ground state energy. This energy is negative and it cannot be smaller. Ground state minimizes both energy and uncertainty. The ground state atom always gains energy when its state changes.  There are two primary ways to excite an atom - through absorbing light (radiative excitation) and through collisions with atom, ion or particle (collisional excitation). Absorbing light is a kind of collision too.
   When a photon (or portion of same) is absorbed by an electron it's inertial parameters are changed.  This results in either a mass increase or a velocity increase.  This can allow the electron to crawl out of the gravity well created by the neucleus.  It does not decrease it's inertia that it was due to the bulk movement of the parent atom.  Any heat energy (molecular motion) is still on board the electron.  Whereas the heated neutral atom is not affected by electrical or magnetic fields the electron is.  Hopefully some of you will understand the implications of taking molecular motion and converting it into electricity directly without the use of boilers-turbines-generators-condensors etc.   We can build an electrical diode but heat diodes are a little more complicated.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
ariovaldo
[size=78%]ENERGIA UNIVERSAL.... KAPANADZE PRINCIPLE?[/size]
[size=78%]
Take a look at this one. Is from March 2012.
[/size]
http://www.youtube.com/watch?feature=player_detailpage&v=2nxdiFxgcvM
