0 Members and 111 Guests are viewing this topic.
verpies
Quote from: sparks on August 02, 2013, 01:34:35 PM
The gamma radiation's ELECTRIC field distorts the linear electric field of the gap.   This results in TWO plasma waves in the CONDUCTORS.  Light to electricity.
Unfortunately gamma rays or light need to arrive from external sources.
If you could cause gamma emission from nuclei, then you'd have plentiful matter-to-energy conversion. (e.g. Colman style)
Electron or ion avalanche in a spark gap by itself does not buy a free lunch.  That's why nobody (not even Sparks) has never succeeded in creating excess energy from an arc discharge.
verpies
Quote from: starcruiser on August 02, 2013, 12:50:09 PM
collecting electrons, isn't that the purpose of a capacitor?
No, charge is not an electric potential difference and charge is not synonymous with electrons, despite that all electrons, protons and ions are charged.
Zeitmaschine
Quote from: verpies on August 02, 2013, 08:14:21 PM
Electrons and negative ions.  Unfortunately they neutralize the"positive end" when they get to it, and it takes work to rebuild it.
Yes, when they get to it. But what if the electrons do not get to it, because something (50Hz circuit with connected load) intercepts them before they can neutralize the positive end?
In the electron trap patent there is no galvanic connection between the positive end which attracts the electrons and the source of the electrons (negative ground) if I understand the drawings correctly.
BTW: Interesting statement in this context from cosmoLV: »Also output transformer is not transformer but choke where High voltage are producing light ionisation second "inductor" produces light magnetic field who is produced by (sparkgap) No more than 2000 triggered volts in frequency of 50 Hz (or by your choice, for example 60Hz) «
This description fits the Barbosa patent very nicely.
verpies
Quote from: Zeitmaschine on August 02, 2013, 09:56:01 PM
Yes, when they get to it. But what if the electrons do not get to it, because something intercepts them before they can neutralize the positive end?
That's a good question.  It certainly is possible to intercept or deflect the incoming electrons (see the attached photo of ions/electrons in a spark being deflected by a magnet).
However, those intercepted electrons constitute negative charge which is continually attracted to the cathode via the electric field. Taking this intercepted charge away from the cathode requires work (as much work as was gained), thus no free lunch here.
It is important to remember that electrons carry potential electric energy (PE) in the form of charge separation (e.g. in a capacitor).
This potential energy can be converted into kinetic energy (KE) (because electrons have mass) by allowing the electron to be accelerated by the attractive electric field of the charge separation.
When this acceleration happens, the PE decreases and the KE increases. If the electron did not radiate photons as it is accelerated then PE + KE = Constant.
If the charge of an electron is neutralized before it arrives at the cathode (e.g. by an encounter with a positive proton) then the cathode ("positive end") will not be neutralized and will be capable of attracting further electrons.  The kinetic energy gained by electrons in this process will not disappear, though. Can be utilzed later...
The problems with this method is that positive protons do not come for free :(
T-1000
Quote from: zcsaba77 on August 02, 2013, 05:25:41 PM
hi for all
Know someone who this guy:
http://www.youtube.com/watch?v=j5bR6BSA72w
I do know him but this might help:
Possible circuit from link in youtube http://library.liberaenergio.org/directory/mrstanlez/
http://library.liberaenergio.org/files/mrstanlez/2012/06-jun/2012-05-27/Kapanadze%20-%20Before%20HV%20test.mp4
http://library.liberaenergio.org/files/mrstanlez/2012/07-jul/29/Mini-kapanadze%20resonator.zip
He's from north-eastern Slovakia (at least from album of photos).
Also I did not found any progress in his files. There are only different things tried and no successful replications.
P.S> It intrigued me for an hour but with these findings there is nothing new...
