0 Members and 134 Guests are viewing this topic.
Grumage
Quote from: elementSix on August 05, 2013, 05:01:53 PM
Hey, I think I found a switch that might work for my Tesla Kapanadze replication.  Since I am broke at the moment, I think I might try this or something similar.  Any thoughts on me using a switch like this to create the Make and Breaks for the Impulse wave??  I will eventually get a Thyristor type of Impulse generator to create much faster Impulse trains and be able to vary the speed of the impulses and maybe see if that will keep resonance.  If not I am sure I can figure another way to do it.
ELECTROSWITCH 6 CIRCUIT ON/OFF 30 AMP/500 VOLT ROTARY CAM SWITCH
http://compare.ebay.com/like/151093915900
Dear element six.
Have you thought about using a Distributor from an old V 8  engine? I am sure that with a little bit of minor engineering you could get up to 3 set's of points inside the housing. Thus giving 24 pulses per revolution!!
Just a thought, Grum.
Zeitmaschine
Quote from: captainkt on August 06, 2013, 04:42:51 AM
perhaps mods to transformer is the way to go as the transformer in bedroom 2004 demo looks tampered with.
This 2004 transformer looks as if there had been something wrapped around the secondary coil -perhaps forming a closed circuit with itself- during one of TK's earlier experiments. Just coincidence?
Quote from: NickZ on August 05, 2013, 09:31:47 PM
So, do you have a link that will open, to view more of his work? Or is it just me that can't get to it? I can read and write in his language
Here are all four patents containing the term »CAPTOR DE ELÉTRONS« in Portuguese (plain HTML). The centerpiece is the ELECTROMAGNETIC DEVICE FOR CAPTURING ELECTRONS FROM THE GROUND TO GENERATE ELECTRICITY which is most likely also the centerpiece of the Kapanadze device.
Below are all drawings of this patent, just in case.
»Abstract
The invention relates to an apparatus that includes at least one device for generating an electromagnetic field (1) - powered by an electricity source - the coils of which are surrounded by at least one single conductive element forming a closed circuit with itself (4), that is connected by induction to at least one connecting conductive element (5), which is connected to a grounding mesh, said connections causing, as a novel technical effect, the appearance of an electrical current that circulates within the conductive element forming a closed circuit with itself, to power external loads.«
Here the operative word is »novel«. A novel technical effect. But maybe »novel« to ordinary people only. ::)
elementSix
Quote from: Grumage on August 06, 2013, 06:15:55 AM
Dear element six.
Yes it has crossed my mind and I am thinking that it would work real well.  Maybe use a small one like from a Honda or toyota.  I was even thinking of using a set of rotating switches at different speed to not only discharge the caps but charge them as well.  Like a set of five rotating distributors all in sequence discharging into one Disruptor coil.  Time them just right so when one is Discharging the other are charging.  The capacitors would have to be solid state or at least have little to no ESR.  I think that would help with the heating problems, by giving each cap. a short rest period in between charging and discharging.  Since they have to be Unidirectional impulses, I would need something like a HV diode to block any back movement.  Like have one diode on the positive line with the spark gap on the negative line.  Or visaversa, which ever works best.  In some of Teslas patent on this subject he uses Choking Coils.  I think they are for forming High Self-Induction, and I was thinking that they may help the disruptor work better.
baroutologos
Quote from: Zeitmaschine on August 06, 2013, 12:35:12 PM
T»CAPTOR DE ELÉTRONS« in Portuguese (plain HTML). The centerpiece is the ELECTROMAGNETIC DEVICE FOR CAPTURING ELECTRONS FROM THE GROUND TO GENERATE ELECTRICITY
To all that know few things about electricity, having a looped inductor sucking electrons of the earth and "puttings" them in "orbit" or circulating them (crowding?) in the conductive medium, and then releasing them again to ground (thus forming current ala Kapa) is heresy! :)
Prove a hint of it and apply for the 2014 Nobel Prize ;)
NickZ
  Here is a new video just uploaded to youtube by Igor Moroz. It shows the start of a self running circuit. It is what I have been waiting for, and many others as well.
  This device still needs to be perfected, but at least it is a real start at this type of project, that can be replicated by us. Diagram included.
  Check it out.
  http://www.youtube.com/watch?v=aWZi3JCBtLM
