0 Members and 211 Guests are viewing this topic.
T-1000
Quote from: magpwr on August 18, 2013, 12:13:39 PM
The part why sweet put magnet in oven is confusing for me before commencing conditioning.
This part is not so confusing for me - http://en.wikipedia.org/wiki/Curie_temperature
When putting them hot on conditioning you can have anything you like in magnet. This also relates to making magnets of Searl device  - http://www.youtube.com/watch?v=vxMHgsmlEfs
The frequency imprinting into magnet is real puzzle for me because that relates to NMR in general but instead of breaking atom in 90 degrees spin precision it is imprinting of that spin with flipping on 90+ degrees of atom for the rest of time... Each atom is small magnet in general and has resistance to flip due binding force between atoms and this is where really interesting part is how it is possible to make them all start flipping so there would be no more resistance.
Grumage
Dear All.
I write this post with "Cap in hand". Our 3.5 Amps was nothing more than the Clipon ameter picking up stray magnetic field generated by the welding transformer!! :-[
Today I bought a new Induction soldering gun. It was with this tool that I discovered the "flaw".  With the trigger pulled on I could bring it towards the Ammeter and the current would rise up to 10 Amps.
This soldering gun creates around 100 A of circulation curret, that is one tenth of that of the welding transformer. So as you can see the clipon would be affected quite a few feet away.
I am now able to report that after a number of different set up's I saw NO current in the earth connection. And yes dear magpwr I even tried your suggestion, to no avail.
Never mind, It got us all thinking, both inside and outside the box!! :)
Cheers to all, Grum.
Zeitmaschine
Quote from: Hoppy on August 18, 2013, 08:24:41 AM
Then why are there three cables into the black box 12V PSU?
I can't see three cables connected to the black box. Maybe I have to clean my glasses first. :(
The bifilar cable to the right connects to lamps and ground. The bifilar cable to the left connects to the 12V input of the inverter (to replace the battery).
But the more intriguing question in this context would be: Does Stepanov use transformers with custom-made coils? Or could it be that those 3-phase transformers are ordinary off-the-shelf transformers?
I have a hard time visualizing a carpenter winding a huge 3-phase transformer with stout wire in his carpenter's shop in order to get (perhaps) an over unity output. Hence we should avoid to push at an open door.
We know electrons can be attracted by a magnetic field. We also know a transformer creates such a magnetic field. Thus, sharp-witted, electrons (from ground) can be attracted by the magnetic field of a transformer. So the tricky part would be, how to add these attracted electrons to the current already circulating in the coils of the transformer in a manner that the overall current gets amplified?
When a magnet moves through a grounded coil then this coil generates a voltage and attracts electrons from ground. But since the second end of the coil is open the electrons have no place to go. Therefore this second end should be connected to something that keeps the electrons flowing. Easy in theory ...
semenihin-77
Статика порождает процесс , это поле надо использовать для усиления действия резонанса.
https://www.youtube.com/watch?v=XjI5CB-QZM4
