0 Members and 102 Guests are viewing this topic.
armagdn03
Quote from: hartiberlin on June 09, 2010, 04:34:21 PM
Hi Guyla,
you are right, the coils have the same B magnet field,
but one has a higher capacitance.
This could effect the Q quality in a resonance circuit and
thus store more resonance energy if you use the coil in an AC resonance system.
Regards, Stefan.
Just by way of information, increasing capacitance does not necessarily equate to higher energy storage in the system, it does however reduce Q.
I wish I could turn my brain off sometimes, then I could get some sleep.
hartiberlin
Quote from: romerouk on June 09, 2010, 04:25:46 PM
@xenomorphlabs
CCW - CW - CCW  from the left to the right
Do you use the same style like user dragon ?
Do you use also one coil of the 3 coils to set the resonance better ?
How many turn do you use ?
Where exactly do you ground the coils ?
Many thanks.
Regards, Stefan.
hartiberlin
If you look again at these 2 videos,
it makes sense to have also additionally to the 6 turn
output coil the loop going through the center of the coils,
cause this seems to add additional induction energy to the system.
Have a look again to these 2 videos for reference:
http://www.youtube.com/watch?v=eH2TWPJiwEA
http://www.youtube.com/watch?v=1rPyc_l-TVQ
aether22
There was a thread about JLN's successful replication of Kapanadze, but now I can't find it?????
http://www.youtube.com/watch?v=PqorIWlkhWI
This seems like pretty big news to me, JLN seems to have cracked it, and while it sure would be nice if he'd make with circuit diagrams this is still pretty big isn't it?
And as I argued on the other thread before it disappeared on me, the number of lights he was lighting in bright sunlight seem to me too much to be explained away by claiming he is lighting them to only about 1/10th of their rated power.
Ok, found the thread.
romerouk
@hartiberlin
I am using 260w in the system and output is at least 500w.The bulbs are more than fully powered.After few more attempts I have destroyed 2 of them.I will have to get some more bulbs tommorow and see how many I can connect and still keep full brightness.I tryed to measure voltage across one bulb and it shows 335v-ac but all  my meters are digital and I am sure it is not right.I need to get some analogic multimeters to find the amps and volts at the output.Few minutes ago I have started the system using DC to power the system an now I can see that DC is the only way to keep the system running for longer period of time.Using ac the spark gap becomes very hot as with dc it is much better.Also having a capacitor 90.02mf) connected in parallel with the load, keeps the flickering under control. I hope the picture attached will make all understand the basic of it.
