0 Members and 112 Guests are viewing this topic.
T-1000
Quote from: elementSix on August 21, 2013, 07:54:48 PM
Who ever that was who posted the Hendershot video links, thanks a lot.  I found the original english video that is 2 and a half hours long and shows you exactly how to make the Hendershot Generator.  Heres the link.
http://www.youtube.com/watch?v=HsKdgLIVnu8
That video is fake one. It was taken from http://www.hendershotgenerator.com/ paid members area.
The original Hendershot device had capacitor inside of coil so that should be easy to spot  - please see hand drawen diagrams in the end of http://www.rexresearch.com/hendershot2/FromArchivesLJH.pdf
Also there is thread about replications of this device in http://www.energeticforum.com/renewable-energy/4771-hendershot-replications.html
Hoppy
Quote from: ariovaldo on August 21, 2013, 02:03:05 PM
Preparing a small test...
Again, using 2 transformers, but the first one with 3 windings :L1, (primary income line 110 Volts), L2 (secondary with 2 turns) and L3 ( with 3 turns ). The second one has L1 ( primary with 2 turns) and L2 ( secondary 110 volts output)
My intention is use the L3 in the transformer one to apply dc or oscillate using diode ( half wave).
I look forward to seeing your results.
I have a 1KVA (10V-0-10V, 50A) transformer which I'm thinking of using in place of a welding transformer that I don't have. There is probably insufficient output voltage to fully replicate TK's heavy load setup but it should serve as a good basis for experimentation. I also have a very large 500VA toroidal transformer that I had already stripped down for a secondary re-wind, that can be used as the second transformer.
Assuming TK used his inverter powered from a battery or the transformer high current 'loop' to provide an isolated supply to bias pulse the second transformer with DC using a 'control' winding, then both half-wave and full wave rectification can be tried, with and without a variable frequency / duty cycle pulse 'chopper'.
I would hope to observe an increase in lamp brightness, which may have mislead TK into believing that a real increase in output energy had been achieved for no additional input energy. On the other hand, he may have discovered an anomaly that genuinely improves power transfer efficiency.
Shokac
I think that this is solution for Barbosa device.
The structure of the circuit - in the open or closed (s) coil (s) 1 and 2, and always in the closed (s) link (s) / loop (s) lead (s) 4 - makes it possible to generate power by and attracting electrons induced by the EM (s) link (s) / loop (s) conductor 4 - where power is generated and stays in motion with or without tension, as the coils 1 and 2 are being fed that is, while its circuit is closed.  Thus, the present invention provides a new concept for power generation, since it is obtained without an electric current flowing in the intake 7 (s) link (s) / loop (s) the fourth conductive even without a load attached consumption to it.
Zeitmaschine
Here is the link to parts list and tools and circuit diagram.
http://www.mediafire.com/download/9yvn66e78n9bf9k/HendershotGenerator.rar
This link is just various generators, not sure why this is linked on the youtube page...
http://www.mediafire.com/download/dz6epheuhcvfe2s/generators.rar
And here it comes, the very simple question: If the shown device is a real working Hendershot device then why can't I find any such Hendershot device on eBay? Neither can I find a ready built device nor can I find a device as assembly kit nor can I find any schematics guaranteed to work.
Have I overlooked something? Wouldn't that be a big hit to sell a working OU device on eBay constructed just out of 6 coils and 6 capacitors?
So until proven otherwise I have to assume that this is just another YouTube fake in order to keep people busy (for a good reason). Besides, what about some measurements? The output of this Hendershot generator isn't 220V/50Hz by pure chance? ::)
ariovaldo
Quote from: Hoppy on August 22, 2013, 05:10:10 AM
I do think the transformer that you have is enough for the test and using a half-wave rectification is a good start. [/font]
About my test, I do need change the L2 numbers of turns. The current is about 800 Amps and I don't have diode with this capacity. The bigger that I have is 400 amps and even that is high...[/font]
The transformer that I have probably will have no room in the window for this coil, but I will try until find out another one.[/font]
Check this configuration and let me know what do you think[/font]
[/font]
[/font]
Greetings[/font]
