0 Members and 55 Guests are viewing this topic.
magpwr
Quote from: Hoppy on August 30, 2013, 10:06:51 AM
Where is the radiator wire connected?
Hi,
No radiator for this video but instead garden tap is used in this video for earth.
Base on my recent 2 ignition coil experiment i found that using earth connection to transistor Base which  allows the 2 x 2N3055 in darlington configuration to somehow resonate with hv spikes without switching off at all.
Unless i remove the earth connection to stop operation.In this experiment i have also proven that experiment as uploaded by youtube user was not a fake since i know the estimated probability if it's real.
Before i even bother to start on the experiment.Original posting by this youtube user whom also reveal schematic in video or in youtube description whom have done a couple of HV experiment http://www.youtube.com/watch?v=pDXKnk9hFMI
My barium titanate experiment is already a ou in mw "Resonance amplifier" which i have posted around 3 weeks ago addressing it  to Wesley and rest in this forum but once the Barium magnet is delivered to me in around 1 month time.I will show what this baby can do in due time.I'm surprised to know the site which talked about resonance amplifier was done in the late 90s.Since then no one in public continued working on this experiment maybe because people don't believe them or material eg:Barium titanate and Barium Ferrite magnet(C8) is truly hard to find which is the fact.
Hoppy
Quote from: Zeitmaschine on August 30, 2013, 10:58:04 AM
The only embarrassing moment I can spot is the non-working spark at 20:20, after TK connected at 19:35 the transformer to the battery. So maybe the transformer draws current from the device (instead of supplying it), hence the spark fails. :D
And actually I'm still a bit undecided whether high voltage is needed or not.
His spark gap HV generation could be a little unreliable when supplies are switched /disrupted. The overall build and wire terminations does not look that healthy!
Hoppy
Quote from: magpwr on August 30, 2013, 11:08:43 AM
Hi,
Then I wonder why he goes to all the trouble in digging a big hole to bury the radiator at the beginning of part1!
I suggest you get your barium ferrite checked out when you receive it from China. Someone I know was sold a pup!
magpwr
Quote from: Hoppy on August 30, 2013, 11:11:50 AM
Hi Hoppy,
I can't really advise on this.But what i know (theory)if you bury a radiator in ground or putting a stake into ground is way better than using garden tap since garden tap is a fixed  location where else the rest can be done anytime or anywhere like an isolated island as an example.
There is a video in youtube on how to verify if your magnet is Ferrite magnet or Barium Ferrite magnet merely by using multimeter set it to ohm reading.By connecting 2 probes on Barium magnet there should be no reading at all unlike ferrite magnet which there is a reading.I have also posted about this video in this forum around 2 or 3 weeks back.
I have no worries since i have already given the chemical properties for Barium Ferrite magnet which you can easily find it on google search and submit it to the manufacturer for (USA standard grade C8 in Sweet VT device) is equivalent to China grade Y-30H-1.
If you just mention Y-30H-1 in itself then it will be "ferrite grade C8 usa standard" which nobody wants.By the way i'm no chemist but it's important to know the chemical properties to submit to manufacturer.hehe
No worries i will sell some excess to serious experimenters with no markup except the delivery cost.The rest will be sold in ebay at whatever price(undecided).
Hoppy
Quote from: magpwr on August 30, 2013, 11:21:10 AM
Hi Hoppy,
You have clearly done your research. Some consider barium ferrite as the 'jewel in the crown'. Best of luck with your experiments.
