0 Members and 220 Guests are viewing this topic.
NickZ
  Grum and All:
  It sounds to me like the camera is being affected by the motors, possibly HV or RF frequency, since the sound is much louder when the camera moves in close. And it may be the same that happens with your Chubinidze set up, blanking out the camera sound or picture.
  We should not discard this quite so quickly. There are also probably other replications to prove it, one way or the other.
  The other experiments with the opposite coils is also worth trying.
magpwr
Quote from: steadyfield on September 06, 2013, 06:39:30 AM
That is a chinese replication of the donald smith device.
see the original post here:
http://www.energysea.net/forum.php?mod=viewthread&tid=1157
and also here:
http://user.qzone.qq.com/278885050/blog/1378191565#!app=2&via=QZ.HashRefresh&pos=1378191565
Please use Google to translate it.
his diagram is in the attachment.
it seems that his replication doesn't need any ground connection.
He (青云Cloud) is also the person who made the 2 shaded pole motors (one modified)  self looping device.
This might not be a fake.
I have one question.
How to calcuate the values of the secondary capacitors to match resonance?
Hi,
This looks like a possible ou device.But the question is how to create a self sustaining unit without the mains
Base on my experiment on usual 50/60HZ 220v mains transformer.The maximum peak power for these transformer is actually 400HZ(military standard) base on one of my experiment.
The big question is how do you plan to down convert around 34KHZ frequency to useable voltage since common transformer is out of the picture.Another factor depend on what kind of circuity is used for stepping down mains voltage inside neon sign transformer in order to isolate from the mains completely.
baroutologos
Quote from: Grumage on September 06, 2013, 05:50:38 PM
Dear baroutologos.
This is the first video that I have seen with a soundtrack in real time. All the others are silent or with music. You can clearly hear a 50 HZ hum that IMO is actually rattling the two motor cores together.  A suitably placed open ended transformer core would provide enough induction through the bench to drive the motors. I am old enough to remember my Uncles Auto electrical shop and one of the devices he had was a demagnetiser. This was like a large flat plate with coils and you simply put the item on top. I have attached a photo of one.
This is how I think this particular "Party trick" is performed. ;) :)
Cheers Grum.
Hello Grum,
So, if you take a powerful open B-flux AC coil run on 50Hz or so, below an induction motor like those, the motor will run - assuming proximity- to almost their nominal speed producing like generators a voltage (enough to light a bulb) Humm... I also saw at the video that the twin motors are raised from table's plane and put almost vertical. The trick works having the twin motors perpendicular or can tolerate wide angle variations to vertical position? (assuming the AC coil below stays in same plane)
I have not experience with this kind of stuff hence i ask. :)
The Czech man who made this "joke" video can send more details?
Thanks
MenofFather
Quote from: elementSix on September 06, 2013, 04:23:15 PM
Just cause Zilano didn't make a video or Pictures, doesn't mean it didn't work.  She told everyone how to make it.  I looked at the device and it seems to be real, but I wasn't around to talk to Her.  Her circuit has been changed like ten times, by God knows who..
Anyways those pics of the Chinamen's device has a Marx Generator in it.  All those Red Capacitors with the resistors and diodes generate HV.  They are also used to create Impulse Waves.  They go right into his Primary Coil that he has inside of the Induction copper tube thats wound CW and CCW.  What I see in his video, I have seen before in a Russian Video.  The Guy uses a Flathead screwdriver and touches the copper coil and sparks are thrown off.  Showing that the metal around the coil receiving the energy put off from it, creates Amps or High Voltage on it.  Must be the HV opposite charge to throw off those sparks.  Any thoughts on that guys??  How that screw driver gets such high energy on it?
What  screw driver?
About Zilano, I thik it might not have, might have overunity divice.
About men, who replicate Zilano and light 60 w 11 lamps, it can light on half voltage, so not 660 wats can be, but about 330.
