0 Members and 214 Guests are viewing this topic.
a.king21
Using the ground as an electron pump can only work at high frequencies and/or high voltage (Tesla).
It will not work at mains voltages.
Don Smith used high voltages and spark gaps to get frequency.
Benitez in the patent  17811 I have referred to, uses a wimhurst machine to get volts and a series of Tesla switches
to get frequency.
Kapanadze uses high frequency and static.
E V Gray used High frequency and static.
Melnychenko in his Russian patent uses static and radio frequencies.
skywalker66
Quote from: Hoppy on October 30, 2013, 11:59:07 AM
Captain,
Its not the losses in the transmission medium, rather the transformation from low tension to high tension electricity and vica-versa at the other end of the line. The system shown in then link posted here shows 50Hz electricity at the consumer end derived from the HV/HF transmission line by step-down transformation. In this case the consumer should see no real change to the nature of the electricity being consumed, so assuming the end transformers are screened, then safety / health risks should be able to be managed at consumer end. As to the safety / health issues in respect of open overhead transmission lines working in this manner, this may prove problematical. I can imagine that avramenko plugs would become very popular for filching electricity from the grid lines for lighting!
About health issues of this tech, we must remember Tesla played most of his live with HV, HF fields, and he didn't contract any chronic disease from that, even more he died old. For me seems safe enough.
Many more others followers experimented with Tesla transformer  for extensive time and remained very alive and healthy (unless they ill from other cause). No one reported some health issue from that.
But the main issue with this energy transmission is not health issues but it is easy to steal energy through even wireless means like a tuned tesla near transmission line.
skywalker66
Quote from: Hoppy on October 30, 2013, 12:22:01 PM
A portable kapanadze style self contained OU self-running system would be much better.  ;D
But bringing a live x wire for kapanadze in the middle of the woods will be even harder, not to mention burying a large radiator there . ;D
Zeitmaschine
Quote from: baroutologos on October 31, 2013, 03:23:59 AM
Easy experiment to do:
Charge a 100uf 400V cap, to 360volts (FWBR applied to 220v mains) Then with a ground wire or your body serving as a ground touch the positive charged lead with one lead of a NE2 neon bulb, holding the other NE2 lead. (you can use an electricians screw driver too) You see that even neon's breakdown voltage is around 90-100volts, it does not light at all. This is because no EMF is exerted on the neon, since it is not connected in anyway with the other lead (-).
Do this with a 25KV charge picture tube as HV capacitor. See what happens. ;D
»The third plate of a capacitor which has a metal can, is the can itself and to use it as a three-plate capacitor, a connecting wire is attached to the can.«
3-Phase capacitors typically have such a metal can, even with screw mounting. Is it pure coincidence that TK uses a whole bank of these capacitors?
1. Is simple to build and has a long, trouble-free life. (that's indeed an unaccustomed feature nowadays)
2. Uses only a few, readily available parts. (from the junkyard)
3. Only a very low level of understanding is needed. (my level complies with this)
4. Once it is installed, the energy provided is free. (what a pity for all meter manufacturers)
5. The energy source is available everywhere. (unfortunately I can't test it on the Moon)
6. It fulfills any and all energy requirements, for example, cars and aeroplanes. (only some power plants will have to close down)
So what's still the problem? ??? :( Did I miss something? ???
Hoppy
Quote from: skywalker66 on October 31, 2013, 05:54:53 AM
Hopefully you are right on the health issues but just because Tesla was not reported to have suffered ill effects from his HF/HV experiments, it does not follow that others would not suffer ill health from exposure to the high intensity electrical fields generated by a national grid network working on this principle. however, I agree that it would be all too easy to steal electricity from such a system.
