0 Members and 476 Guests are viewing this topic.
Hoppy
Quote from: jbignes5 on October 31, 2013, 03:31:24 PM
No the challenge was thrown down to you and the others who like to talk the talk. It seems all you do is talk especially on the subject of Teslian technology. I on the other hand have been busy with experiments and when my lab is operational I will show all. Videos will be made and like I said all will be shown and nothing will be hidden. So again if all you got from my last post was the challenge then I humbly ask you to reread the whole thing then do the work. It is very simple.
Thanks but no thanks. You are clearly an authority on the works of Tesla, so it will be much simpler for you to show us how we should go about building a self-runner once you have built your own and posted your videos.
Grumage
Dear Zeitmaschine.
With regard to your recent posts. Three plate capacitors.
I recently went to visit an old friend of mine who has been in the business of variable frequency drives for over 30 years. Typically I was on the "Cadge" For redundant cap's etc.!!
I was specifically after high value Non polarised capacitors. The next sentence may be of interest??
He said that you could connect the two positive plates of electrolytic capacitors together and then use the negative plates as a non polarised cap. This was something of a shock to me!!
However could this be the answer to a three plate design? I am just thinking laterally!!  :)  BTW I have not put this to the test. Has anyone else??
Just another thought, Cheers Grum.
Zeitmaschine
Quote from: Grumage on October 31, 2013, 06:04:42 PM
Two caps connected in series is still two times two plates design. As I see this, it has to be one electric field (not two) in one capacitor but with three separated plates. The third plate should influence (the electric field of) the other two plates.
So let's say plain and simple, make a 50Hz resonant LC circuit, then connect the can of the cap to high voltage (and high frequency) and some other part of the circuit to ground. See what happens. Nothing unusual, I'm afraid. :(
And I'm still puzzled why I can find this sentence ...
»The only limit on the output power is the size of the capacitor«
... just on one single website (because they forgot to delete it), although that document from Don Smith is said to be published on 14th February 2004!
What's going on here? A conspiracy perhaps? 8)
Quote from: jbignes5 on October 31, 2013, 09:21:07 AM
Me and a friend worked on the 3 plate cap. We called it a captret. Very interesting device. There is something about the 3 way of plates mixed with capacitance that allows it to energize the other plate via the electric field. This energizing effect further polarizes the cap. Sorta like a non polarized cap being made polarized. Once one set of plates forms a charge the other plate gets a sympathetic charge for free. It uses a common pairing of plates from case to negative plate of the cap to form the capacitance. Then you hook your device to be used to the common connections of the capacitor to pull power from.
This was extrapolated from experiments where one could touch the can of the capacitor and energy would appear in the capacitor from seemingly no where. Every radio guy will attest to this.
Every radio guy? Could it be that every radio guy is in error?
Asking, because this website states:
»Chapter 9 (page 69). The removal of the section on captrets as I and several others have investigated them in some depth and are of the opinion that they are exceptionally difficult to analyse, are liable to damage capacitors and they appear to produce no useful power
So does that mean all other stuff in that PJKbook on 2586 pages does produce useful power beyond all doubt but they are absolutely sure that the captrets do not? Hmmm ...
And by the way, the two diodes on that three-plate capacitor reminding me of a statement from someone called teofiliuss: »In the output of the Turk device are powerful diodes. They fix output energy.«
Maybe that's just another coincidence. ???
P.S.: Also removed from that book David Wells Weather Control, because it is too powerful! :(
jbignes5
I just wanted to show you that no and I mean no frequency but our own bodies provide is enough for getting power from the ground.
http://www.youtube.com/watch?v=FVKbhK5vvgU
dllabarre
Quote from: jbignes5 on October 31, 2013, 07:16:09 PM
Along those same lines is this healing device:
http://www.u2ecom.com/PersonalEngy/personalenergydevice.htm
I know first hand that this device works.
DonL
