0 Members and 269 Guests are viewing this topic.
Alik
All devices are on the same Kapanadze effect is sparking a certain gas ( in the case of hydraulic liquid to power it ) ( in the video he turns freon gas bottle is a welcome refueling of air conditioners when it is filling for " wet" ) (( (Goal sparks - Getting atomic hydrogen. ....) )))
Simultaneously, this amount is equivalent anode part of the fuel cell , the atomic hydrogen is sent to the magnetic flux ( it replaces part of the electrolyte ) fuel cell conditioned , ground water and the air cathode is a portion of the fuel cell conditioned ... (many fuel cells are open systems )
( somewhere Tariel told him that the earth can replace the negative terminal BATT )
it will still work and to run the ( weak pull) and some time after the launch ....
Our gain is the acceleration of protons in a magnetic field .... + recombination matter ...
Discs Kapanadze mentally continue mechanics Kapanadze ( this rotation is stupid mechanical chopper plus a comfortable inertia) becomes the core shaft . Small coil begins to reel big trees between takes . The discs begin to spark the hull ... and again the white matter (a consequence of the sparks in the gas )
In the case of banks, he did brilliantly , he falls gas straight from the can to spark ... Rude but car ...))) well done ... )))
There was a story here ....
Persian-Princess Sh-Pr
1996 .
I once had to travel from Moscow to Yaroslavl, and a neighbor in the car was
muzhichek some 50 years , and now I have it by chance were talking about electrical engineering ,
and in particular about whether "anywhere " to obtain an increase in the power circuit.
And then Uncle Nick told me this : it turns out it works
electrician Wrappers at some factory in Kostroma .
And he and his colleagues produced a crafty power transformer
to power the machines in the shop . But the essence is this:
primary cell wound wide copper tape
across the width of the window of the core , or rather even tape
and copper sheet in a few turns and resale plain,
copper bus , i.e. wire with the receiving voltage 380 -400V .
Served on a primary DC from the rectifier through the car breaker ( timer )
while at sharp pulses with copper tape is reset mysterious substance
type of gas or liquid can be hands feel
strongly pricked hands if exposed to the winding.
Between themselves, they called it a green or blue flame fire.
A shot from the secondary winding with a mad power
that was more than enough to power 4 lathes.
Soon found out about this company's management ,
children received a reprimand , a transformer had to be dismantled immediately ,
deprived of many awards , as if for the classes in the workplace,
topics not related to the work itself .
Threatened with dismissal.
It happened back in 1972 .
Then I came in Yaroslavl , but no contact Uncle Kolya did not take ,
did not even ask any name, nor that of the company where he worked, shy shorter ...
Something similar happened here, guys ... probably in the workshop were the remains of welding gases inside the BATTERY apparently sparking gap ... He stood up so well that the magnetic corridor formed atomic hydrogen ... white matter than it is faced with atomic hydrogen in the air ...
Apologies for the automatic translation
PS ...... Proton is our CE- brother it can disperse in a magnetic field is nothing on it without spending a ...
Tool for removing the power .....
Schematic diagram of the hydrogen fuel cell ... Overclocking the magnetic field in the area of standard electrolyte ... The presence of an electrolyte can be bypassed .. using .... The mechanism Grotgusa
It remains of course the question should be immediately removed from the chain of the fuel cell (ie before the earth wire .) ? .. or accelerate protons flow along the way and still be working on the further winding removal definitely oriented ? ? ...
Все девайсы Капанадзе на одном эффекте идет искрение в неком газе (в случае с гидравликой он сжиженный для мощности)( в видео он переворачивает фреонный балон это прием заправщиков кондиционеров когда идет заправка по "мокрому") (((Цель искрения - Получение Атомарного водорода.....))))
Одновременно этот объем является анодной частью условного топливного элемента, атомарный водород направляется в магнитном потоке (это заменяет электролитную часть) условного топливного элемента, заземление с воздухом и водой это катодная часть условного топливного элемента... (у многих топливных элементов это открытые системы)
(гдето Тариель говорил что заземление ему может заменить отрицательный вывод аккума)
оно будет еще работать и до запуска (слабенькая тяга) и некоторое время после запуска....
Наша прибавка это разгон протонов в магнитном поле....+ рекомбинация вещества...
Диски Капанадзе мысленно продолжают механику Капанадзе, (это вращение тупо механический прерыватель плюс удобная инерция) Вал становится сердечником. Маленькая катушка начинает большая катушка между валами принимает. Сами диски начинают искрить о корпус... и опять белое вещество (следствие искры в этом газе)
В случае с банкой он сделал виртуозно, он падает газ из банки прям в область разрядника... Хамски но прокатило...))) молодец...)))
Произошла вот такая история....
1996г.
Пришлось мне как-то поехать из Москвы в Ярославль, и соседом в вагоне оказался
некий мужичек лет 50, и вот у меня с ним случайно зашел разговор про электротехнику,
а в частности о том, можно ли "ниоткуда" получить прибавку мощности в электрической цепи.
И тут дядя Коля мне такое рассказал: оказывается он работает
электриком-обмотчиком на каком-то заводе в г.Костроме.
И они с коллегами изготовили хитрый силовой трансформатор
для питания станков в цехе. А суть вот в чем:
первичка наматывалась широкой медной лентой,
по всей ширине окна сердечника, точнее даже не лентой,
а медным листом в несколько оборотов а вторичка обычная,
медной шиной, т.е. проводом, с учетом получения напряжения 380-400В.
На первичку подавался постоянный ток от выпрямителя через автомобильный прерыватель(трамблер),
при этом при резких импульсов с медной ленты происходил сброс загадочного вещества,
типа газа или жидкости, можно руками было почувствовать,
сильно кололо ладони, если поднести к обмотке.
Между собой они его называли зеленым или синем пламенем, огнем.
А с вторичной обмотки снималась при этом бешеная мощность,
что с лихвой хватало для питания 4 токарных станков.
Вскоре об этом узнало руководство предприятия,
ребята получили выговор, трансформатор пришлось демонтировать срочно,
многих лишили премии, как-будто за занятия в рабочее время,
темами не относящимися к самой работе.
Грозили увольнением.
Было это в далеком 1972 году.
Потом я вышла в Ярославле, а вот никаких контактов дяди Коли не взяла,
даже не спросила ни фамилию, ни что за предприятие, где он работал, постеснялась короче...
Нечто подобное и здесь получилось ребят... видимо в цехе были остатки сварочных газов, внутри аккума видимо искрящий разрыв... он так удачно встал что образовался магнитный коридор атомарного водорода... белое вещество это то с чем столкнулся атомарный водород в воздухе...
PS...... Протон это наш СЕ-брат его можно разогнать в магнитном поле ничего на это не потратив...
Инструмент для снятия мощности.....
Принципиальная схема Водородного топливного элемента... разгонное магнитное поле в районе условного электролита... Наличие электролита удается обойти..используя....Механизм Гротгуса
Остается конечно вопрос снимать следует непосредственно с цепи топливного элемента (например перед земляным проводом).?.. или разогнанный протонный поток по пути поработает еще и над дополнительно обмоткой съема определенно с ориентированной ???.....
verpies
Alik
Zeitmaschine
Quote from: verpies on November 13, 2013, 09:01:48 AM
That is different because in that case we have a time a time varying magnetic field that does work by pushing the charges away.
In your pot/cage system, the work was supposed to be done by the attraction of separated opposite charges coming together.
Then I would urgently appreciate answers to the following questions:
a) Has the Earth an electric field?
b) If yes, does this field contain energy?
c) If yes, can this field still exist within a Faraday cage?
d) If no, then can the energy of that field perhaps be found in the walls of the Faraday cage?
e) If no, where did the energy go in order to not to violate the law of conservation of energy?
These are rather simple questions, I think. 8)
verpies
Quote from: Сергей В. on November 13, 2013, 08:48:57 AM
COMPLETE FOR TODAY's "SCIENCE" THE CORRECT WORD "IGNORANCE" IS OUT OF GOOD HEALTHY LOGIC AND MIND - HER MAIN GOAL TODAY IS COMPLETE ABSURD !!
IN NATURE DOES NOT EXIST NOR POSITIVE CHARGES NOR NEGATIVE !! EVERYTHING IS MUCH MUCH SIMPLER AND IN SAME TIME ABSOLUTELY GENIOUS !! THANKS MOTHER NATURE !!  :D
This is not far from the truth as I see it.
The mechanics is lost to virtual particles and intrinsic spins and we have too many fundamental axiomatic units.
- kilogram
- meter
- second
- coulomb
etc...
