0 Members and 490 Guests are viewing this topic.
bolt
Quote from: hartiberlin on June 11, 2010, 03:37:21 PM
Forget output measurements with these pulsed systems.
Also with analog meters.
Just put your 900 Watts load on a normal 240 Volts AC Line and
compare just the light output with your eyes.
You can also use a Lumen Meter.
Or convert your output to pure DC via Graetz bridge rectifier and
a big LC lowpassfilter bank and then measure pure DC at a defined ohmic
resistive load, like a toaster wire or 1000 Watts type heater resistor.
You also really need to shield the measurement equipment from these pulses
with the right ferrrite bead lowpass filters in your measurement cables.
It is not easy to measure correctly.
So better go with the light output comparison side by side,
but then you need a 2 x 900 Watts bulbs setup.
hartiberlin i agree with you 100%. Once you attempt to measure the o/p on these systems then falls back to the thousands of threads arguing about the alleged readings. Its very difficult to get a reading on RF hash in the KW's range as will be seen in these Kapanadze systems. Even in RF Transmitters they use an RF load resistor which is dropped into a large container filled with oil.
Eyes are good enough and use one bulb if required plug into mains as a reference lamp for video is good for others to make comparison. In fact this should be a defacto standard for reference on ALL vids to show one bulb same type as others as a reference bulb it would have saved 50 pages about KAPAGEN bulbs being half lit.
ALSO if you use GDT's on each load and they increase brightness THEN peak out as can be sure hit the 250 volt limit then you know the load is maximized.
At the end of the day its up to the end user to establish if he is actually getting extra loads driven for free. Its never been a case of a 10 milliwatt joule thief being OU or not its about practical use and that is what REALLY matters. So if my power meter says 250 watts i/p and im running 10 off 100 watt bulbs plus a 1kw fan heater am I going to argue about the readings?? I doubt it. Its not important and every installation will be different depending on precise build standards and earth rod resistance etc.
cell1
Hi,
My impression is Tarie Kapanaze uses the coaxial cable. I see that when they show the sparkgap.
I found a book when is show how you can calculate the coil. There are some excel file to calculate directly the coils. I hope is useful.
http://dl.transfer.ro/Ultimate_Tesla_Design_Mitch_Tilbury-transfer_RO-11jun-70fcd5.rar
Excuse me for bad English.
Best Regards,
Cell1.
hartiberlin
Quote from: callanan on June 11, 2010, 09:19:03 AM
Regarding the cable in the coil tube. Has anyone noticed that romerouk uses many insulated wires twisted together and stripped at each end and twisted together again. This will in effect create many shorted one turn loop coils which will resonate at very high frequencies. It is possible that JLN has done this also but it can't be seen. Perhaps this is an important requirement of the coil. Hopefully I will test this very soon.
Yes, Osssi, this would be  a good explanation.
Yes, please try it without it or with a direct coil through the center, what I posted a few pages back.
We really have to see, what this inner cable will do.
Many thanks.
Regards, Stefan.
hartiberlin
Quote from: cell1 on June 11, 2010, 03:54:14 PM
Hi,
Best Regards,
Cell1.
Wow, an over 400 Pages PDF ebook about every aspect of a Tesla Coil.
You could read months in it...
This is probably information overload right now, but maybe in the
vaccations you could read this a bit every evening...
Many thanks for this info.
baroutologos
Excellent said admin.
Please romerouk (and everybody experimenting at the moment) consider using a fast/powerful FWBR, smoothing caps (i see you have a lot) and the load you are using side by side with the same load powered by mains.
This way we should know for sure. lets have a minimum scientific approach at least.
