0 Members and 99 Guests are viewing this topic.
d3x0r
Quote from: Jury1 on December 23, 2013, 07:03:39 AM
The man who invented «качер» - Владимир Ильич бровин,  can not answer the question – «that there качер»?
His definition of "качер" includes all the the blocking oscillators with feedback ...
In Russian forums  many newbies make no distinction between blocking generator  and качер, they are referred generators -  качер ...
I think, that  Kacher is a special operating mode of the transistor. This mode is located before starting the avalanche breakdown transistor. IMHO
(from RU02075726 patent search
Application Number:   93031244/28   Application Date:   03.06.1993
Publication Number:   02075726   Publication Date:   20.03.1997
Publication Kind:   C1
IPC:
6 G
6G 01B
Applicants:   Brovin Vladimir Il'ich
Бровин Владимир Ильич
Inventors:   Brovin Vladimir Il'ich
Priority Data:
Title:   (EN) SENSOR TO MEASURE TRANSLATIONS
(RU) Brovin SENSOR FOR MEASURING MOVEMENTS
Abstract:
(EN) FIELD: Technology measurement. SUBSTANCE: sensor to measure translations has high-frequency generator built on transistor and three windings coupled inductively. First winding is placed into collector circuit of transistor and forms together with second one positive feedback of generator. Second winding is brought into emitter circuit of transistor. Third winding is placed into output measurement circuit of sensor and is mounted for movement relative to first winding. EFFECT: enhanced operational reliability and stability. 1 DWG
(RU) Usage: measuring equipment, displacement transducers, in particular, to measure the size. The inventive sensor comprises a high frequency generator and three transistor inductively coupled windings, the first of which is included in the collector circuit of the transistor and constitutes together with a second positive feedback oscillator. The second winding is included in the emitter circuit of the transistor. The third winding is included in the measuring circuit of the sensor output and is arranged to move relative to the first. 1 yl."
can't find patent original which would have the pictures referenced...
https://sites.google.com/site/atmosferalis/stati/brovin-kacer
http://www.youtube.com/watch?v=WmquYxZ1SVI  ; бровин о качер (in russian)
Edit: Finally found the PDF attached here.
So; turns out the first schematic is not the intent... although connecting a coil in such a configuration at the emitter to ground did reduce power and increase output
Hoppy
Quote from: captainkt on December 23, 2013, 10:23:54 AM
@Hoppy, more interesting, look no 50Hz on the scope and bulbs which flash about a bit - again without a smooth 50Hz.
Keith
Hi Captain,
Yes, like Kapanadze the grid supply is 'processed' into a complex waveform so as not to be accurately measured by DM's. Probably pulsed at low frequency with induced HV from the Kacher.
I hope the next fake is a lot harder to suss than this broomstick device.  ;D
verpies
Good point if you know the horizontal timebase setting on that scope.
Indeed, 50Hz is hard to filter out completely.  Only fully-blown power supplies can accomplish that.
stivep
f
Quotereeenergyinfo СЕЙЧАС НА САЙТЕМодераторFreeEnergy-FreeInfo[/i]Сообщений: 1402Спасибо получено: 2589
ДОБРИ ДЕН ИЛИ ВЕЦЕР ВСЕМ ....
ЙА ВЦЕРА ПЕРЕПИСИВАЛСА В МАТРИКСЕ В ЦАТЕ С АВТОРОМ VASMUS ...
ОН ДАЛ ЕМАИЛ СВОИ .
ЙА ЕМУ НАПИСАЛ ПИСМО С ПРОСТИМИ ВОПРОСАМИ .
1. УСТАНОВКА РАБОЦАЙА ИЛИ ЕТО ФЕИК ??? ?
2. УВИДЕТ ЛИ НАРОД СХЕМУ И ОПИСАНИЕ НАЛАДКИ УСТАНОВКИ ??? ?
ВОТ НИДАВНО НА СВОЙУ ПОЦТУ ПОЛУЦИЛ ОТВЕТИ ОТ АВТОРА ...
ЕТО КИНО БИЛО НОВОГОДНАЙА СУТКА ...
ТО ЕСТ ЕТО ФЕИК...
ФАЗА ПОДАВАЛОС ЦЕРЕЗ МЕТЛУ ВЕРХ ...
ОБЕСАЛ ПОДУМАТ И МОЗЕТ БИТ СНИАТ ВИДЕО ГДЕ ВСИО ОБЙАСНИТ КАК ОБМАНУЛ ...
РАЗ САМ АВТОР ПРИЗНАЛСА СТО ЕТО ФЕИК
ЕТУ ТЕМУ ЗАКРИВАЙУ ....
ВОТ ТАКИЕ НОВОСТИ .
ОПИАТ НАДНАМИ ПОСУТИЛИ И В ДУРАКАХ ДЕРЗИТ ....
ЕХХХХХ...............
SKYPE freeenergyinfo
И уж точно не наличие СЕ делает человека человеком.
antanaslietuva@gmail.com
freeenergylt.narod2.ru/
www.youtube.com/FreeEnergyLT/
www.youtube.com/AntanasEnergy/
Well what Antanas says  is:
that there was conversation with  someone who said he is Vasmus and statement was that was is fake
So subject was closed by Matrix forum
The problem is that I Wesley do not believe it was fake
I do not know the motivation and  what is behind it nor I care about.
Wesley
