0 Members and 76 Guests are viewing this topic.
grizli
I did not follow this thread for a while ?
Why after some time of being away from this topic, I read at many places on youtube coments/ etc t hat Kapanadze device was fake and what fow proved ?
Is it true ?
Farmhand
Quote from: a.king21 on January 05, 2014, 02:08:22 PM
I investigated the Brazilian device thoroughly. Unfortunately Brazil uses a system of single wire earth return.
Therefore it would be impossible NOT to get energy from the earth. They would in effect be stealing electricity from the grid.
This leaves the Brazilian authorities in a catch 22 situation.
Publicize the inventors and millions of Brazilians find out how to get electricity from the ground or try and keep it quiet, yet somehow stop the inventors. So no wonder the Brazilians wear gloves!! I know I would.
Georgia does not use a system of SWER.
Single Wire Earth Return systems are only for High Tension long distance transmissions I think.  The current flows through the ground between the HT transmission transformer and the step down transformer.
http://ruralpower.org/swer/swer-how-does-it-work
http://en.wikipedia.org/wiki/Single-wire_earth_return
Quote from the safety section of the Wiki.
QuoteSWER systems are designed to limit the voltage in the earth to 20 volts per meter to avoid shocking people and animals that might be in the area.
Now the ground current path has the same wave along it's length as the wire does as far as I can tell and if one was to ground two rods at say a few klm's apart along that current path then energy could be tapped as a potential difference would exist. EDIT to add: I dare say away from the grounding points the current would flow quite deep in the Earth. That would be my opinion.
Alternatively if a tuned Tesla wireless receiver was tuned at 50 Hz and was well grounded along the current path it may well be capable of stealing power from that grid system.
A Radio transmitter on the other hand has a radiating concentric wave of current through the ground which could be tapped pretty much anywhere close enough. This I believe is what allows a ground connected crystal radio to work so well and why one crystal set can be used to harness power at a different frequency to amplify the signal of another intended for listening to. If the transmitter does not radiate from it's antenna and had a frequency and power enough to resonate the planet with the ground currents then the waves could be tapped better with less loss, unlike the weak ground currents from a HF radiating antenna. Is how it looks to me.
The Single Wire Earth Return Systems are basically the Tesla system of Single Wire energy transmission. Although just try to find some credit given to him for it.
http://www.google.com/patents/US593138
Wiki stray voltage.
http://en.wikipedia.org/wiki/Stray_voltage
Cheers
stivep
http://youtu.be/rx8_DJr0TTg
or  try
Wesley Translate's Akula video #12 Akula's TPU part 1
http://www.youtube.com/watch?v=rx8_DJr0TTg&feature=youtu.be
Electromagnetic Generator TPU That is different than Traditional Free Energy Akula concept.He presents 4 channels phase shifted generating PCB with /scope.
The concern is raised and reasoning is examined. Is similarity of both the major concern, or is that time factor concern for Akula to keep public interest till the next step. I'm positive that his device works.( the first one) I'm also trying to give little something about electrostatic pump concept.
Happy New Year
Wesley
HG8AD
MasterPlaster
Quote from: Acca on January 05, 2014, 03:53:50 PM
Akula0083 latest video clip link below in Russian and some screen shots..
http://www.youtube.com/watch?v=UcwXMq3bUZI
[/font]
@Acca, Please can you re-post the schemaic in high resolution?
Thank you.
