0 Members and 212 Guests are viewing this topic.
Dave45
Hey Farmhand I like your posts you try to analyze the actions, Tesla said the oil quenched the spark made it sharp an fast.
What happens when we short a coil in a transformer??? high current starts running through the windings, this would increase its magnetic field, so if the coil were shorted at the peak of the sine wave it would drive the magnetic field up higher than normal then a sharp chopped fall, this is exactly what we want.
You say its not ou and it may not be but its going to be fun to find out  ;)
In the article I pasted last post he states that peak to peak switching is what we want, its a good read Im going to go over it again.
I read that when they tried to patent logic gates that they couldnt because Tesla already had  ;D ;D ;D ;D
Its gonna be the same, when we find it we will find Tesla already patented it years ago  ;D
Dave45
Quote from: Zeitmaschine on January 12, 2014, 06:55:25 AM
Actually I don't know what the purpose of this patent is at all. It creates high frequency current from low frequency current. But what for? What load »translating devices E« (?) would need high frequency current in order to work (the year is 1894)?
As depicted in Figure 2 there is not much room for a spark to occur between the wheel I and the connectors G.
»Within the extension I secure two cross-bars H which afford bearings for the spindle of a small metallic turbine I, the blades of which, as the turbine revolves, bridge the space between the two terminals, nearly or quite touching the terminals in their movement.«
That description sounds to me rather like a rotary switch than a classical rotary spark gap.
Capacitors
Rectify it smooth it, use it  :) simple
Zeitmaschine
Quote from: Dave45 on January 12, 2014, 07:38:48 AM
Capacitors
Can't see any rectifier in that patent. In 1894 it has to be a mechanical one.
Quote from: Hoppy on January 12, 2014, 07:04:34 AM
Given TK's international fame within the FE community, I reckon that if he had faked self-running, then he could financially gain from writing a book about how this was achieved with his various devices. I imagine it would make a best seller!
He could also financially gain from writing a best seller about how he achieved real over unity. ;D
Dave45
Aviso said igbt's are what we need to short the coil, he also said it multiplied the power three times.
a.king posted this vid awhile back
http://www.youtube.com/watch?v=wC6aglJ6a_8
Dave45
Quote from: Davi on January 12, 2014, 05:27:34 AM
With the help of theoretical bases of electrical engineering defines the conditions to obtain the free energy with the use of capacitor and inductor. Found an increase energy 25:1.
Click here for details  http://www.tarielkapanadze.ru/science-cond-eng.htm
Notice the ramp generator, it switches at the peak, when we use a zero switching circuit the field falls into the primary as well as the secondary this causes reactive power (wasted power - heat) but with peak to peak switching the field is driven from the peak, not allowed to fall, no reactive power.
Now all we need to do is boost the magnetic field a little, right at its peak  ;)
