0 Members and 42 Guests are viewing this topic.
verpies
Quote from: Dave45 on January 12, 2014, 10:09:33 AM
current creates a magnetic field,
Yes, but magnetic field is a vectorial quantity - not scalar.  This means that it also has a direction in addition to magnitude.
if we have a coil with 3 amps running through it wouldnt the same coil have a larger magnetic field with 7 amps running through it.
Yes.
Quote from: Dave45 on January 12, 2014, 07:07:25 AM
...this would increase its magnetic field...
Quote from: verpies on January 12, 2014, 09:58:12 AM
No
Why not ?
Because magnetic fields oriented in opposite directions don't add up to a larger sum.
When analyzing transformers you must consider the vectorial sum of the magnetic field created by the electric current flowing in the primary winding as well as the magnetic field created by the current flowing in the secondary winding.
pepsimaxzu
its fundamental things guys..
i belive current go from ground, when TK said "ground can be replacet by circuit" then "circuit" means some plate from aluminium or copper, or big selfinduction coil.
a.king21
Quote from: pepsimaxzu on January 12, 2014, 12:59:23 PM
TK told me the "circuit" could be the negative terminal of a car battery.
In other words he told me the ground wire could be terminated  on the negative terminal of a car battery instead of ground.
This is pure Tesla.
a.king21
Quote from: captainkt on January 12, 2014, 12:09:07 PM
@Farmhand and Dave45, quickly tried motor with fourcontacts on end, sort of rotary switch. Set it up as Tesla with shorting coil on secondary of first transformer, all going well as 500watts of bulbs start to brighten up, however the back emf in first transformer gets in sync with the motor driving the rotary switch and within seconds the motor and all my circuit went up in flames. So this may be reason for driving with oil or keeping well isolated. Before the motor experiment I was trying IGBTs for shorting but could not get them to switch cleanly at all they just turn on as frequency increases to anything useful. Unfortunately I left them (3 parrallel) connected on one side of circuit when playing with motor they all exploded in flames with the rest of wiring and components. After todays playing I am sure that shorting coils is the answer.
Keith
Pleas, please post this circuit. It is vital we analyze it.
Dave45
Quote from: verpies on January 12, 2014, 12:42:06 PM
Yes.
Why not ?
Its the secondary being shorted so the shorted current should travel in the same direction as the original current flow, magnetic field should be the same orientation, should kick the field right at the peak.
Iv seen your posts and highly respect your opinion but still gonna try  ;)
We need a power oscillator like the mazilli circuit but instead of zero point switching we need a circuit that switches peak to peak.
