0 Members and 72 Guests are viewing this topic.
elementSix
Quote from: dllabarre on January 13, 2014, 08:04:04 PM
So if someone DC pulses a primary with +12 -12 +12 -12 what is the wave form in the secondary?
He is not pulsing anything, he is creating a different energy form.  A combined + and -.  Impulse is a lot different than pulses.  They come together in the primary/discharge circuit, an intermittent discharge of a circuit used to create a static like energy form that is akin to lightning.  Thats why the ground wire is so important for it to work.   You need to create the same energy form that is in the air and the ground for it to suck anything from it.  You can't use wall energy to pull a totally different energy from the ground, you use the combined dc poles to create the cold currents and those will be your lever to prime the secondary coil.  Resonance is so important, not just because it helps store up energy, but because it keeps the dc energy in the discharge circuit from getting destroyed in the process.  If it does get eaten up in the circuit, it basically taints the process and you won't get shit out of it.  Thats just how I see it and of course I am just an amateur and uneducated.
ps like I have said earlier, AC can be used but the make and breaks have to outpace the Cycles per second..
Farmhand
Quote from: elementSix on January 14, 2014, 12:09:33 AM
Yes, HV DC but he can use lower voltage also.  The quote here is from his text.    . In systems of this character when the high frequency of the currents employed is due to the action of a disruptive or intermittent discharge across an air gap or break at some point of the circuit,  He is running it off Impulsed dc currents.
That passage of text is describing what is done by the spark gap not the supply generator. The supply generator is driving a transformer with AC, the "chopping" happens later.
Ok I give up. I have better things to do. In my opinion a 50/50 square wave is AC, less than 50/50 duty is alternating DC pulses, DC pulses all the same polarity are unidirectional DC pulses.
But the patent is driven from an AC generator. As is the generator symbol often used by Tesla.
Others are quite entitled to their opinion. So I'll argue no further.
verpies
Quote from: Davi on January 13, 2014, 09:53:42 PM
Dear verpies!
Where you can download a guide to transients in electrical circuits in English.
For example here
P.S.
If you are not computer savvy and don't know how to download these files, then write me a private message.  Whatever you do, do not use the option "Direct Download" or you will be sorry.
verpies
In an ideal transformer: Rectangular
Farmhand
Quote from: verpies on January 14, 2014, 02:24:21 AM
Yes exactly correct, depending on the amplitude and the frequency the rectangular dimensions change.
A direct transition from positive to negative the applied signal would be Alternating Current and when there is dead time they would become alternating polarity DC pulses.  :)
