0 Members and 36 Guests are viewing this topic.
jbignes5
Quote from: Grumage on January 18, 2014, 01:59:50 PM
Dear Farmhand and jbigness5.
First, please find attached  Tesla generator patent. Is this the patent you are both referring to ??
Farmhand, I watched your video I wondered if you had got the bifilar crossed?? But I think the action you were seeing IS important, please don't scrap that video just yet. Better still let T-1000 see it !! BTW what is your core made from ? Is it segmented ?
More importantly I wonder how this Generator would perform with a rotor ??
Cheers Grum.
Addendum.
You could see this device as a mechanical TPU !!  ;)  Possibly Lenzless ??  ;)
No this is the patent:  http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
The important thing here is the patent needs to be done in full and not in some percentage of completeness. Everything must be installed on the same rotor. The motor must be done exactly like Tesla reported in the patent. I think most people fail in this kind of endevour because they don't know about the transformer action, They tend to create high magnetic fields around the rotor and that isn't right. Using Tesla coils around the field core will create a transformer action in the field coils and reflect any magnetic field back as higher voltage. The generator does not turn the rotor the motor does. The only thing the field cores do is center the rotor perfectly with magnetism. Oh and generate even more high voltage.
And yes I see the TPU in this design. How that relates I am not entirely sure. Maybe people were trying to disect this in smaller bits to see if the magic was in the one part. The magic is the whole device and method not just a single aspect. When people focus on one little thing then you see the trouble they get into.
I got about 3/4 of the whole unit done. I need the harness and motor left to build. I got everything I need to make the magneto generator field cores and coils. No gen rotor yet either. Ok so maybe half of the device to go yet. Bearings will not be an issue just need to be high speed. The self centering of the rotor in the field cores should keep it from having too much play. Tesla said even a poorly made system ran beautifully because of the self centering ability of the rotor.
stivep
Sumermagor4 hours ago
stivep, what is going on in here? i mean what could be the possible explanation of the effect that we are seeing here, the energy must come from somewhere, how could this be achieved?
stivep1
1 hour ago (edited)
I see it as a pump. everything i nature want to go to its balance.
If there is difference of potential on plate of capacitor, connected one side to the ground, than electrons from the ground flows to  balance it,and let's say because of inertia it is over balancing it just for fraction of the second before it levels up.
But  another coil that  is loosely coupled with capacitor  is using this overbalance that  is induced in it during "temporary overbalance"
Electrostatic charge is faster than physical reaction of matter( electrons- can flow hours for 1 meter wire length)
That coil is connected to light-bulb( resistive load).
In resonances there is little or no impedance and energy has easier to flow and than dissipate in bulbs.Than there is a need for a balance  again, and again, and again, The only required force is 9V  starting force.
Analogy: at certain speed car pushed by 5 people needs only 1 finger of the lady to push, just to sustain the motion  (or balance losses).
So if you are able at that point to deliver (free of charge) let's say-3 times required energy, the car would speed up and go to  OU still sicking to balance itself.
Sumermagor
2 hours ago (edited)
so as i understand what you were saying is that, when we introduce a current in to a primary coil, then the driving source makes that first input which does the hardest job to "start the car to roll forward", then we are introducing a second current which would be the " finger" to push the car to speed it up, with very little effort.
so we have the first part which starts the process and the second to speed it up till infinity.
may be im confused, this is what you are talking about?
stivep1
1 second ago
+Sumermagor not  like that but similar to that.
The hard part is 9V battery to start the device:create  electrostatic potential.
Using Tesla coil.That=balance.first 50Hz generator is started.
INFORMATION IN CURRENT FLOW IS FIRST  THAN  FLOW OF ELECTRONS IS SECOND( string theory)Information is immediate(static electricity).
Than he (Vasmus) mess-up with balance
By introducing high voltage picks That series of impulses,will be  given starting from 0V of sine-way to max of its amplitude.
And with amplitude, many times higher than  50Hz sineway.
That creates temporary dis-balance that needs to be balanced by electrons from ground wire.
But when you create the mass inertia  you deal with "temporary overflowmas you activated mass in its own ,
That capacitor that  needs balance
I was talking about in my previous comment is COIL with large diameter of plate like wire( high  capacitive reactance)
Than next to it you heave another coil  that is connected to lighbulbs and is in resonace to 50Hz,
That is why you can not heave one of the lightbulbs more or less in that circuit.
Overal impedance of that  circuit than  (while in resonance) is  small.
That is why  lightbulbs  decipate energy  throwing  circuit to disbalance that was about to be reached. But small amount of that   inertia  driven disbalance is used to create "samozapitka" selflooping  to sustain next cycle of disbalance.
Wesley
forest
vdomov
Here is the original patents Kapanadze Turkish. Please can someone translate them.
d3x0r
speaking of pumps...
and really off the subject entirely
MHD process to split water plasma and get electricity directly
Blacklight power announces test Jan 28....
http://www.youtube.com/watch?v=Cuzlyu4czYs
http://www.blacklightpower.com/
