0 Members and 155 Guests are viewing this topic.
FreeEnergyInfo
Quote from: Hoppy on January 26, 2014, 01:17:51 PM
Nah, just a couple of ultra thin EC wires connected to the battery leads. The electronics is just converting the incoming high voltage on the wires down to low voltage to drive the halogen lamps.  ;D
Che a large radiator? To anything he's there, the transistors.
Between the board and the heatsink can easily hide the batt from the tablet, especially if frezernut niche, the rest - the boost converter and the stabilizer, the accumulator in this mode too, the radiator does not hurt, 3 minutes high-rate discharge:
size: 4.0 * 70 * 100mm thickness of 4 mm, and thinner can be:
3-7V-3000mAH-Li-ion-Polymer-lithiumion-battery
а че такой радиатор большой? Ни к чему он там, тем транзисторам.
Между платой и радиатором запросто можно аккум от планшета спрятать, особенно если нишу фрезернуть, остальное - повышающий преобразователь и стабилизатор, аккуму в таком режиме тоже радиатор не помешает, 3 минуты разряда большим током:
размер: 4.0*70*100mm  4 мм толщина, может и тоньше бывают:
ru.aliexpress.com/item/3-7V-3000mAH-Li-ion-Polymer-lithiumion-battery-for-7-inch-tablet-pc-Q88-teclast-onda/719825148.html
Hoppy
Quote from: FreeEnergyInfo on January 26, 2014, 01:24:13 PM
Yes, a distinct possibility.
Grumage
Dear All.
I think I caught a bit of Hoppyitis !!  :) :) :)
But please look at the attached expanded photo ?? !!
Time will tell !!
Cheers Grum.
FreeEnergyInfo
Quote from: Grumage on January 26, 2014, 01:48:18 PM
Dear All.
Time will tell !!
Cheers Grum.
HD photo  , video ...
http://yadi.sk/d/Q4doot0wGmZFj
