0 Members and 138 Guests are viewing this topic.
NickZ
   Did Bearden show a working example of his circuit, as here are many unknowns in the diagram above?
forest
Quote from: NickZ on March 18, 2014, 12:00:50 PM
  Forest:
  Can you provide us with the link to Igor's video that has English subtitles.
   Obtaining a properly working feed back circuit is the most important aspect to continue working on the self runner circuits.
              NickZ
https://www.youtube.com/watch?v=qBxUsfHHKrM
first part here https://www.youtube.com/watch?v=xRQFngNLIsA
elementSix
If you wish to make a Don Smith device you have to look at what his setup says.  Dont look at it as a whole.  First he has a variable input into the NST so he can adjust the input voltage. Also a varible resistance on the ground connection.  Thats number one. Second is he uses 2 blocking diodes to create a Unidirectional Input from the NST.  How that diodes don't destroy themselves, I don't see how they wouldn't, but maybe they are special.  Third he has a combination of Series and parallel resonant circuits.  To tune the device. A ground connection on the output with a capacitor parallel with the center tapped  ground. The spark gap position is also special.   He said later that he only hide all this so he would be able to get the information out there without being a target.  Now if its the truth is up to the experimenter. I hate to say that the capacitors have to be special in some way.  That way I have soon forgotten, Sorry.
He says that this circuit is the basic operation of the device.  I hope it will help you.
captainkt
Hi @ll just a note to all experimenters, I got fed up with spark gaps stopping and burning and lack of stability. What I have done is put spark gap inside tube capped each end then filled with pure argon under pressure, left cylinder connected to keep pressure in - I used 2 tungsten twist drills  and fixed them with small bore pipe fittings through each end. I could not believe the difference, as pressure increased the spark increased from 1mm in gap to 30 or 40mm and very lively I had to move the points apart in end fittings. Decrease pressure and spark dies back. Now got to find a way of using this info. The power supply is flyback transformer.
Keith
gyulasun
Hi Keith,
You are surely aware of off-the-shelf surge arrestors which are just gas filled 'spark gaps".  See a gas discharge tube firing at 90V DC here http://www.digikey.com/product-detail/en/CG90LTR/F4109CT-ND/2745247 and many other choice at random search here: http://www.digikey.com/product-search/en/circuit-protection/gas-discharge-tube-arresters-gdt/655426  up to 8.5kV.
Of course when you can make your own gas filled devices you do not need to buy such but perhaps this info is useful for others tinkering with DS circuits.  Several other part sellers include such, and there are choices at ebay too.
Gyula
