0 Members and 138 Guests are viewing this topic.
elementSix
I'll write another post so you dont have to look thru all that BS.  Just be a little patient,  I will take my time and write all thatI know about the process.  It's about 95% of it.  AKING21, you know exactly how it works, Italked to you about it months ago when you pointed out that Carlos Benitez patent.  There are many ways to create the phenomenon, and thats why there are so many different devices that all achieve the same outcome.  I have been pondering the Don Smith way and he uses that darn Neon sign module and uses two blocking diodes that run to one side of the primary.  Now I dont understand how the diodes don't burn up..  But he also uses Impulse waves to create the negative atmosphere that allows the ambient background to flood in.  The problem with the energy we use from the wall is it has a positive pressure.  The negative pressure is low pressure in the discharge circuit wich is exactly the way you need it to be.  The low pressure is the lever that opens the ambient door and allows it all to work.  Smith uses resonant circuits that block the certain frequency to bounce back and forth in the system.  The key to that is making your primary, capacitor, secondary to resonate at the frequency that disturbs the nucli and brings out the NMR effect.  You have to find an NMR chart with the response frequency and the magnetic field strength that is needed for that frequency to work with the wire/copper that you use to create spin spin in the field that is in your area.  Thats why smith brought out that map that displayed the earths magnetic field strength in areas around the country, so that you would use that data to calculate the frequency of the AC that is needed to create NMR.  Theres a new way that is being used in EFNMR and it uses pulsed DC.
NMR Frequency Table
http://math.ut.ee/~laurit/AK2/NMR_tables_Bruker2012.pdf
Now lets skip to TK.  He uses Impulse waves which is  using Low pressure system that doesn't keep the Ambient valve shut.  The problem is inductance, capacitance, resistance ect.  all have to be just right for the impulse to work right.  I don't have a scope or any good equipment to work with, so I can't see whats going on.  But i am pretty sure that you want a very thin impulse.  Tesla had a few things to say on impulse wave length and the outcome from the different lengths in a coil system.  Tuning is a bitch because even the way you wrap the secondary can change the capacitance and you can help yourself by using an adjustable HV capacitor.  I am going to make the one Tesla patented for use in this very system.  It's just two plates in boiled out oil that can be adjusted in the distance between the plates and help tune the way the wave acts in the air core transformer.  You can have a great make and break device and perfect primary turns and secondary placement and if the resistance is not right or the capacitor doesn't resonate the wave right it won't work.   TK gave the example on  a russian forum years ago when he answered some questions, that if you beat your foot on a bridge and timed it right, so that when the wave returned and you hit it at the right time, you would add to that wave without expelling anymore energy.  Which is just like the kid on a swing analogy.  If you push the kid right before he returned to the maximum height, you would just have an under unity driver.  But I will write more, have to go.      FK the Illuminati.
                 E6
a.king21
RE the Don Smith diodes.
He mentioned in one of his talks that he had them specially made
and you could only get them from him.
captainkt
@a,king21-A good few years ago I bought the Don Smith CD, and he talks about special caps made as a favour to him, but not diodes, elementSix says cut the BS and then still does not even give us a clue. Low pressure and tuning, I have been trying to tune my circuits for years, with variable caps and coils, low pressure, what is that all about ? It is the down to earth in plain language method of operation we need, so that we are tuning the correct circuits in the first place. Peferably TK's method as this has not been disproved and has useful output and does not need expensive components.
Keith
Enjoykin
Hello folks
This is my 1st mail here. It's a HIT about Crimean public prosecutor Natalya Poklonskaya - Amazing Hero of Japanese Internet and Japanese Comics too !!
Absolutely Amazing 5 844 690 views for only 5 days.
Enjoykin — Nyash Myash
http://www.youtube.com/watch?v=TBKN7_vx2xo
Thanks for watching !!
