0 Members and 137 Guests are viewing this topic.
xenomorphlabs
Quote from: jeanna on July 05, 2009, 12:46:51 PM
I have never been able to capture anything at all in a cap from this secondary unless I used both a full bridge rectifier and 2 more diodes. I collected plenty and watchout for the sparks then!!
@Jeanna,
i might be misinterpreting the circuit, but it seems to be AC capacitors after the transformer.
Because the first capacitor before the transistor is explicitely marked with polarity, but the other caps are NOT . If i am not mistaken, they dont require rectification.
Have you used AC caps or CD caps when you have tried it?
Apologies if my thought is wrong.
@All:
I have an understanding problem with the images of Donald Smith and Kapanadze set-up.
They both seem to have all their coils on a single PVC tube.
Does this tube contain the different core materials in sections?
Would that not couple the transformers magnetically? (Maybe thats even intended ???)
I have not enough experience with transformers set up like this, that´s why i ask this question here.
xenomorphlabs
@Stefan : My girlfriend has completed the translation of the Tesla Transformer video that you were interested in. She has translated it straight and has not tried to fix anything in the sentence structure, we thought its best that way.
Here it is and is hopefully inspiring to some ;)    :
QuoteHere we have the analogy of a Tesla’s transformer (converter?)
If we look at the construction of it, we will notice that it vaguely reminds of a transformer, because here there is pretty no inductive connection, repeated-primary winding, or how we call it, inductor, consists of only 3 turns (coils), but very thick, and here there are about 250-300 turns.
However the circuit works and gives a very powerful discharge, we call it Ñ,,ЕТТОННЫЙ [Phetonniy] (the translation to this word I didn’t manage to find, maybe it’s really their special term).
Also discharges happen all around us , if you look, here it is going. You also can notice that the discharge flows out of the screwdriver towards the coil.
Now we will change the circuit. We will connect one more coil to this coil. See what’s happening.
As a result, the second coil became a charge carrier too.
And we see that it also takes charges out of screwdriver. The lamp isn’t connected to anything. Just a sheet of paper and lamp’s wire is lying on the floor.
However the lamp is burning. It means that the space is excited to the state when the secondary current emission appears in surrounding metallic objects, it means that the object is not connected, but the emission appears.
And this means that there’s a transfer, no, not a transfer of energy, but the information about energy to the surrounding space, it is in excited state here, cause if we touch any object, we see how does the system work (that weird sentence).
This actually is electrostatic energy transfer. The capacity here is only about 15 Watt, but the effect can be observed. With the proper influence upon the surrounding space it provokes appearance of electromotive force like reaction in return.
By analogy if we put any metallic object here or even hold it in the hand, the lamp will burn, because the electrons will be induced, also there’s pretty no isolation from this current, it pumps out pretty from everywhere. So this is Tesla’s transformer (converter).
And if we look at the instrument, we see that it shows the presence of powerful field. The instrument isn’t connected, it reacts. We can observe where the intensity is the biggest, it is here near the receiver.
If we move the instrument away, we see that the intensity is falling down. Here are some more phenomenons that are hard to be estimated like the influence of body, of everything on the registration of the instrument.
It means that everything is so alive around, that it’s hard to imagine. So all the electrostatic transformers and generators originate in here.
And the next continuation of electrostatic machines is so-called “The pipe” plan. Here is similar winding plus one more external pipe is put in. The high-voltage potential is supplied on the pipes and it is taken off from the coils. But as a result of uncontrolled growth, the pipe is punched out (пробиваÑ,ÑŒ â€" I don’t know the exact translation of this word here).
This is more or less powerful version of Tesla’s transformer, that is closer to practical use.
Pirate88179
Xeno:
Thank you!  Please thank your girlfriend for us as well.  We really appreciate all of her efforts.
CRAY
Hi ppl!
Unfortunately right now i'm not as cool as you in bringing free energy into masses, however i speak russian language and i want to help you.
So if anyone needs translation of docs, videos etc - tell me. I will be wery happy to do my bit ;)
Good luck!
Sony
Pirate88179
Sony:
Welcome and thank you for your kind offer.  We need all of the help we can get here.  I am sure you will be able to help.
