0 Members and 160 Guests are viewing this topic.
hartiberlin
@romerouk,
I am glad you want to share your results.
Maybe if you have a scope you can do an easy experiment for us ?
Please wind a small pickup coil, like 10 Windings of 0.2 to 1 mm diameter copper wire
onto a small plastic or paper tube and put this just across your scope,
so you can pickup the signals from your kapagen coil magnetically from a distance
and don´t need to connect your scope directly to it
and then please make a few scopeshots from this pickup coil ,
so we can see the involved frequencies.
Then please use different  capacitors in parallel with your
6 turn coil and also show scope shots of it and just only
change the capactor value and try to trigger correctly the scope,
so you can get about 2 to 3 complete cycles onto the scope display..
Please note for each scope shot the volts/div and usec/div or millisec/div,
so we can calculate some frequencies and amplitudes from it.
This would very much help the process of optimisation.
Many thanks in advance.
Regards, Stefan.
P.S: Does anyone of you is still in email or phone contact with Jean Louis Naudin ?
I have emailed him twice lately but he does not answer as I wanted to visit
him in France this summer, but he seems to be too busy.
Many thanks.
Quote from: grizli on June 13, 2010, 05:49:26 PM
depends on resonance frequency.. HF no core needed ... lover frequency bigger core if same material used
That's a broken answer. Noone has dared so far to somehow look at the wave form of this special setup but it's assumed to be in tens of kHz. This assumption means that direct closing the loop will need added circuitry to account for the MOT. However ferrite cores operate in this range with low losses and can offer direct looping at any frequency without having to worry about frequency conversion. Since they are relatively cheap it's worth a try. Especially when people can donate to further the progress.
Pirate88179
Quote from: grizli on June 13, 2010, 04:37:27 PM
what is the frequency of current that goes through earth ? would it mean that earth itself as capacitor oscilates at some low frequency ?
The Telluric currents frequencies vary depending upon conditions and location on the globe but they have been measured from less than 1hz to about 5hz. Very low frequencies.
bolt
Quote from: aether22 on June 13, 2010, 04:35:39 PM
You preach about the flaws in this system, but at least someone replicating this has a chance of success.
What odds of success does someone have of successfully replicating the kind of transistor system you speak of even if they do a competent job?
If you had success and detailed plans to copy great, but clearly you don't.  Dissuading people from trying this Kapanadze style OU device is purely wrong unless there is a viable alternative.
By all means post suggestions people can make after they have tried the main JLN/RomeroUK design but it is important people replicate this.
BTW I have offered RomeroUK $300USD if he provides extremely detailed plans and instructions for replication, especially details of his coil, had no reply but maybe other would like to add in a dollars to twist his arm for absolute detailed disclosure for fully reliable reproductions.
note: this offer expires if I get success and hence can provide my own documentation.
I am not preaching flaws im offering solutions. I already stated that KAPAGEN is a good platform to learn how to tune and system basics towards  OU device. Its already stated yes it works but runs too hot and makes too much noise and EMI so i post solutions for improvements.
You do realize if you run these things for too long you could be wiping out half the TV's in the neighborhood or block out local airport comms and if you do that expect the FCC to come round with a SWAT team and kick your ass. You will get a BIG fine and ALL your stuff confiscated. That is why it need refining and the sooner the better.
Why do you need to spend 300 bucks for plans its has been posted here many many times now its a coil thats all.
e2matrix
Jeezz you guys are posting messages faster than I can read here...  :o     I found this document I had saved that was in Russian and just ran it through Google translator.  I then picked out some possibly relevant tidbits and these are from a Russian forum and some from SR I believe.  For what it's worth I think there may be a few good tips in here if you can understand the translation:
1) Looking for short unidirectional impulses.
2) The coil contains ferromagnets. Mention Melnichenko.
Where do you see that spark Kapanadze feeds directly in the primary? Yes, I also conducted experiments on the discharge
on the primary, HF always will be, but if you enter the ferrite core in the circuit, the picture will change dramatically.
Based on the presented devices, there can never be a high frequency of those devices would otherwise have gone sum and would show a complete nonsense. Why do you think that the Tesla transformer will not work at 50Hz? Because the
resonance frequency depends on the environment in which it is placed. Place the ferromagnet into the secondary housing, and
you change the permeability of the medium, respectively, secondary housing will resonate at lower frequencies.
Video "Green Box" on the screen can be seen
in the middle of the primary coil is visible black material, more like a set of ferrite rings. Regarding the similarity of devices Smith and Kapanadze - is repeatedly mentioned in this thread. As for the modulation, this does not yield the desired result, the carrier frequency what to do?
I also believe that the most important element of the device is hidden from the eyes or skillfully disguised.
The presence of the iron core does not preclude the resonance, but merely shifts the resonance frequency in the lower range.
Yes, the device Kapanadze have resonance, but it is not parametric.  (from someone who apparently has the secret of the device and has made it work -- SR ??)
Yes, the arc is important in the installation, but it plays a very different role, he is not involved in switching.
Many people think that can not be output frequency 50 Hz with a secondary winding of the transformer installation Tariel
(hereafter UT), and this too is fundamentally wrong! I want to say that for the formation of sinusoids used power bipolar
transistors are PNP and NPN conductivity, each in its half-wave, and how it works with the transformer is not going to say.
Many forums are trying to stick a feedback to the UT (kapanadze device)  is also not true, there is no feedback
5) Output transformer UT hardly be called Tesla transformer, but the ordinary man in the street might think so. But the
principles they are quite different.
6) In UT no nanosecond pulses and WASO has no relation to UT.
80% of the principle of the installation can be seen in (the Kapanadze ) video installation of 100kW
one of the elements of this mosaic is in the video madsatbg
We can say 50% Tesla transformer. But still they used slightly different guidelines than the Tesla transformer. Although one of
the patents, Tesla is mentioned, but not in the patent Tesla transformer. All that said Kapanadze is true, but people do that
distort the meaning of spoken words.
I want to note that the "coil" is removed the voltage on the line, without any converters, frequency of 50Hz. Any connection of the load, even through the arc is not allowed to do so, whether there is a resonance circuit.
With regard to industrial frequency, the device is done Kapanadze elementary and less expensive than using an inverter.
Moreover, the formation of 50Hz is one of the highlights of combining two functions: forming a sinusoid (not unipolar pulses, namely a sinusoid), whose frequency can be easily controlled and more important function, which I will not mention. Naturally there are obstacles introduced by the secondary field, which sometimes affects the readings, some of this interference is eliminated grounding total output of the transformer.
They do not use a resonance oscillating circuit and the load is not part of it.
2. 50Hz is formed by a simple method to resonance irrelevant. Oscillatory circuit is not there.
I recommend everybody out of his mind the phrase "resonance oscillating circuit. Word of the resonance has a different meaning in the installation.
