0 Members and 279 Guests are viewing this topic.
stupify12
What would people call the extraction of energy from a resonant system without disturbing the Resonance of the so called Transmitter?
Tesla 8) 8) showed many ways on how to extract energy with out reflecting it from the source. Look on Tesla's diagram which He showed powering the bulbs or motor with only 1 end from his Transformer/Device. Replicate those experiments which Tesla showed powering any bulbs or loads with only 1 wire/end from the coil, anyone will understand that the Energy we are looking is what Tesla called Radiant Energy.
With conventional energy the always result will be Underunity. With the Radiant Energy Phenomenon the result will always be Overunity. Imagine powering the loads like bulbs and motors with only 1 Wire/End of the coils, so basically it is not consuming energy from Magnetic Coupling. ;D ;D
Remember Ground/Earth is your main storage of Electrons/Ions.
Meow.    8) 8)
Quote from: Khwartz on May 07, 2014, 01:24:11 AM
Hi Stupify12. So, did you get overunity like this?
stivep
Notice:
You might find that some information  in this article overlay itself or  are repeated in different form.
That is due to , number  of changes and additions I have made after posting this article.
I believe that  this article is influential both to you and to me  as I must have think what  is really happening in TK Akula Device.
Tell me what you think?
[quote author Name will be  mentioned upon approval ]
QuoteHi Wesley, do you think there is any correlation between the Akula coil winding and a Halbach array in terms of how the magnetic fields interact with each other?   http://en.wikipedia.org/wiki/Halbach_array
Good question.
In ferrite we deal with micro-compound of  mostly Iron Particles that has been placed in rotating porcelain cylinder and water for  period say 24-36 hours.
than the particles start to develop rust.
Rust has  high  DC  resistance and add to overall impedance for AC.
Than that  mass is dried and mixed with joining compound.
Than  the mass is being formed to desired  shape.
The permeability of ferrite is one of  characteristic properties.
Permeability  of air is 0.
Quote(degree of magnetization that a material obtains in response to an applied magnetic field
http://en.wikipedia.org/wiki/Permeability_(electromagnetism)
The whole purpose of ferrite is to prevent eddy current and   fight with saturation of the ferrite.
So in that we are not dealing with magnets  but only with  temporarily aligned ferrite particles ( domains)
After influence of external magnetic field is   stopped than   each of the domains  goes to its own direction. (dis- alignment )
Therefore  speculation of possible similarity between
Halbah Ray  and ferrite  is not applicable - first one operates with presence of  magnetic field of steady magnetized particles.
However Halbah concept is interesting from the point of :
- view of non magnetized  magnetic recorder   tape that allows controllable magnetization in the tape .
- possible implementation of array inside  HV coil to create magnetic regions in the coil.
actually this is very interesting.
interesting is:
Quoteto high-tech applications such as wiggler magnets used in particle accelerators and free electron lasers
to find this mechanism as particles accelerator.
http://en.wikipedia.org/wiki/Wiggler_(synchrotron)
QuoteThese deflections create a change in acceleration which in turn produces emission of broad synchrotron radiationtangent to the curve, much like that of a bending magnet, but the intensity is higher due to the contribution of many magnet dipoles in the wiggler. Furthermore, as the wavelength (λ) is decreased this means the frequency (ƒ) has increased. This increase of frequency is directly proportional to energy, hence, the wiggler creates a wavelength of light with a larger energy
Yes the higher the frequency the bigger is  electric potential of subatomic particles.( electrons- but not only)
Say photon of UV is at much smaller energy level than photon of X-ray and smaller than  photon of Gamma.
In synchotron we are dealing with mass of particle not with photon alone.
So wiggling  is a property of accelerated mass particles in order to push that particle to higher energy level.
Part of that  accelerated particle energy is  lost due to Gamma and X-ray side effects.
But photon does not have mass nor charge.
Photon has energetic level measured in keV to MeV at most of common applications.
Photon can however have much smaller or higher energy.
QuoteHalbach cylinder is a magnetized cylinder composed of ferromagnetic material producing (in the idealized case) an intense magnetic field confined entirely within the cylinder with zero field outside. The cylinders can also be magnetized such that the magnetic field is entirely outside the cylinder, with zero field inside. Several magnetization distributions are shown:
Here I can point at impedance of ferrite material.
As every  "electric interacting " body it contains capacitive and inductive reactance there for it has impedance that  is different in different   frequency of  oscillation.
example for AC at no Halbah effect  included but at traditional TK, Akula mechanism:
By implementing spikes from another generator ( square  wave) on the top of low frequency carrier from first generator you  imitating action of acceleration in mechanical motion of child on the swing.
At this time impedance is changing  rapidly in  swing push motion
Mechanical response  of the ferrite creates creates  delayed answer to the  impulses. Vibration makes induction of the magnetic field in the coil around so is in effect  another additive to  magnetic flux.
electrons from the ground are responding to change of impedance  if the change of impedance has a need  for them to flow to the Akula or TK device than that is what is happening.But the electrons have their own inertia.
The device might act as a trap.
Before  energy is able to be returned . inductively coupled circuitry of the load dissipate that energy and another demand for flow from the ground is needed. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Notice: in this I did not included NMR yet.
I draw you  simplified picture of mechanism of energy extraction from the ground due to ferro resonance
I also want to point that ferrite noise was present in  Lithuania Experiment, akula 1000W generator, SR, TK Tiger and so on.
http://en.wikipedia.org/wiki/Inductor
QuoteAlong withcapacitors and resistors, inductors are one of the three passive linear circuit elements that make up electric circuits. Inductors are widely used in alternating current (AC) electronic equipment, particularly in radio equipment. They are used to block the flow of AC current while allowing DC to pass; inductors designed for this purpose are called chokes
that means that  high amplitude picks of  square signal over low frequency carrier  at very top of the pick are DC impulses. And they  are allowed to pass and magnify  ferroresonance.
Below you will find:
-Basis for explanation of said above ( fat print)
-discussion about Halbah effect
- ferroresonance as mechanical stimulation ( induction of  current due to mechanical   displacement even if there is no voltage applied)along with mechanical inertia= delay in dissipation acting as part of pumb when impulse  from generator is not present
- sumary
There is no capacitor that has 1 MKF.
There is no  resistor that has  50 Ohm
But there is all from the above at frequency of 1KHz as this is standard  for marking parameters of the components.
You might have however resistor or capacitor that has broad Impedance within the  marked region( written on the component)
In Halbah concept:
By that token we might see ferrite as  3D structure  that is due to permanent  magnetization ( kept after  RF influencing factor is not present)
In not Halbah concept:
By that token we might see ferrite as  3D structure  that is due to  non-permanent  magnetization ( kept after  RF influencing factor is not present)But still  yet dying mechanical vibration is inducing  current in the coil around.So is creating magnetic field  back magnetizing domains of still vibrating ferrite
Presence of arrangement  as in  Halbah by creating regions  creates different  response to external electromagnetic field in the coil where Halbah is placed to.
That makes change to overall impedance AT GIVEN FREQUENCY ONLY .
also  as mechanical size of domains is large and only insulating material is between  magnets frequency of response  must be lower and inertia must be enormously   higher in resonance.
Resonance will be at frequency of mechanical resonance  will be very low. If achievable at all it will be due to  very high power impulses.
The only way  when we  will see any current in coil around Halbah in any arrangement is when there is  physical displacement ( change in location- mostly mechanical) of  Halbah magnets or coil.
But !!
regional impedance in space  differs just because  there is presence of  magnetic regions.
Think about it as huge magnetic tape that we can program but will not get demagnetized if any external field is applied
or
Such change will have recovered  after   any external field is stopped.
or
hm.....
With change of  any external field interaction  is regionally changing  in the regions.
and here we go.
Ferroresonance is mechanical as well.
When ferrite gives you sound it is response of  ferrite particles to the level of energetically increased any external field
Now we are dealing with motion.
Motion is the physical mechanical displacement that  must produce current in the coil or any conductor( the closer it is the better - inverse square law)
That is the scenario similar to us
Moving magnet in the coil without any potential  applied and producing current , voltage( charge) so is power  in the conductor.
That is also due to change in capacitive reactance of ferrite particle (* mechanical displacement)
As particle is so small than bonding compound and rust is the insulator of the domain( one single metal piece)
Please do not forget about  additives to a ferrite that contributes to permeability.
THERE IS SOMETHING INTERESTING IN IT.
mechanical nature of vibration at given frequency.
Why?
Because electromagnetic wave is based on no mass  photon energy.
So it "can not interact" with the matter as mechanical accelerator.
So why it does? :)
And we now it does?
I would like to know  how many of you can answer this question :)
Summary.\
We might have need for something to move with respect to excitation frequency and by inertia it stays longer  for one more impulse or  more than one.
Similar to swing  and the child on the swing at max  deflection momentary being not pushed any longer at right moment ( max of amplitude)
Eventually that swing will dissipate its energy however is not  so simple.
- fire from spark  uses at first  spark and than energy of flammable source.
- water valve needs  first to be open and than it uses energy of say river.
- sucking water in  plastic tubing with your mouth makes water to flow  and so on.
The common mechanism of it is delay suitable enough to  produce  external force response.
One of mechanisms of delay of impulse can make electrons from the ground wire to be sucked  as the result of primary force ( say mechanical vibration of ferrite)
But that is only simplified  speculation.
I did not touched nuclear response of the matter.
And I have been under influence of that response in LITHUANIA EXPERIMENT prolonging my pain in head  several days after my return  to USA from Lithuania.
That was also felt by everyone  person in the room of Lithuania experiment.
Interesting is also that in most of sytuations Akula was using  Ferrite in Flyback mode
Flyback means that core is not closed in one leg  there fore acting as storing energy device(read about cpacitive reactance of ferrite)
-also in Lithuania experiment (I and Aidas) we have been placing piece of  paper  in between two halves ( up to 1KW achieved)
example a:
-also look at small rings of insulation in Akulas flash light  rectangular core ( during  disassembly of his transformer)
(example b:)
-Also think about ferrite cup as middle of  ferrite cup insulation from opposite cup  in another flashlight  video concept
(example c:)
example a: https://www.youtube.com/watch?v=gbeseiPPCeM minute 6:25
example b: https://www.youtube.com/watch?v=1BNgo09N0yM
example c :https://www.youtube.com/watch?v=Lpx1SJdXnmo
Wesley[/quote]
Khwartz
Quote from: stupify12 on May 07, 2014, 02:31:12 AM
Meow.    8) 8)
All this is quiet interesting and probably essential for the subject but I am very sorry to note you did not answered my question :/ dear Stupify12.
stupify12
Overunity could be achieve if you can find the way to destroy the Inductance either of the Primary and Secondary of your Transformer. I have found the answer from Nikola Tesla.  It is so simple you'll laugh.  Well yes it is ultimately Overunity  . One thing I observe on this device when loaded- the energy output will amplify  because we have already eliminated all the negative factors that oppose our input to deliver a Ultimate output.
See you   guys. ;D ;D
Meow   8) 8)
Quote from: Khwartz on May 07, 2014, 04:49:41 PM
Khwartz
Thanks for your reply, Stupify12.
Would it mean you have yourself acheived overunity or it is still theoretically way to say it should be? And if you have achieved indeed in the real world it,  could you indicate me your possible vids or schematics?  Please.
Regards.
