0 Members and 187 Guests are viewing this topic.
hartiberlin
Hi romerouk,
please also try to hook up your current probe meter
at least a few meters away on an extension cord where you use in front of it
some toroidal ferrite core rings and put the 50 Hz extension cord a few turns
through it.
This will block the RF pulses from the spark gap going back to your current probe
meter and shield it to mess up the measurement..
So better also additionally wrap your current probe meter into alufoil or even
better into a iron cookie box together with the extension cord cable
and the ferrite toroidal core and view the
current just through a hole, so it acts like a farraday cage...
If your current probe meter is so near your sparkgap without any lowpassfilter
and shielding I would
not trust its measurements.
Many thanks.
Regards, Stefan.
xenomorphlabs
Quote from: bolt on June 13, 2010, 08:34:33 PM
Still looking for "magic" spot frequencies. I say again its not important. OU can be tapped from Hz to Gigs. If not how do you explain a 1 ground OU device or groundless like the TPU? The fact that certain wave events occur at certain frequencies are not in themselves the source of energy.
What about air cap casimir dipole? No earth as Don Smith device operating frequency is Ghz. Wavelength is millimeters. Where is the source wave now?
Method to reach OU is pretty much universal despite operating frequency.
"Prentice got more out at 500khz." of course he did the higher the frequency the more joules pumped per second. Back in the day 500khz could always be achieved with relative ease by a spark gap but going over 1 meg or higher got a bit more difficult. This is why Don Smith uses 25khz NST's it high enough to do whatever you need off the shelf parts. If you want more power then step up the volts to 50kv or 100kv etc using coils. Now you have more potential joules the trade off is finding components that can handle extreme voltages.
So if the exact frequency does not matter, what do you mean with the circuit requires tuning? :
QuoteActual frequency values are not important as RE exist at almost any frequency only the circuit requires tuning. When make tuned circuit where current is out of phase to voltage power APPEARS to be ZERO
is that the PF correction measures that you talked about ?
EDIT: You answered that question already with the following words:
QuoteTuning means power factor correction on i/p and o/p plus chokes, HV diodes to DC, correct size for spark gap cap plus ballast and tuning L1 very carefully to L2 using Binary Cap box and adding the right value caps in all the right places till its peaked into a given load.
Could you elaborate on L1 to L2 matching? What indicates a good match?
vrand
Quote from: e2matrix on June 13, 2010, 06:34:51 PM
Jeezz you guys are posting messages faster than I can read here...  :o     I found this document I had saved that was in Russian and just ran it through Google translator.  I then picked out some possibly relevant tidbits and these are from a Russian forum and some from SR I believe.  For what it's worth I think there may be a few good tips in here if you can understand the translation:
Thank you for the translation  :)
Where was the original Russian site url link?
Has anyone reproduced the Kapanadze device on the Russian site?  Photos or videos url link?
Thanks, Mike
xenomorphlabs
Quote from: vrand on June 13, 2010, 10:24:17 PM
Thanks, Mike
You can´t access that site ("next-energy") anymore because the admin called SR closed it shortly after making the post (that was translated on the previous page) and claiming that he figured out how Kapandze´s principle works.
You find photos of his set-up when you read through the last 50 pages of this thread, as it was discussed here already.
It has not been successfully reproduced.
vrand
Quote from: xenomorphlabs on June 13, 2010, 10:44:05 PM
Thanks xeno  :)
So really, JLN was the first to publicly reproduce the device and showed a video of it working.  Then Romerouk reproduced it and explained all of the parts needed for experimenters to reproduce.
So the ratio of Russian kapagen reproduction success is, 0 in 10,000.
Regards, Mike
