0 Members and 268 Guests are viewing this topic.
e2matrix
Quote from: vrand on June 13, 2010, 10:24:17 PM
Thank you for the translation  :)
Where was the original Russian site url link?
Has anyone reproduced the Kapanadze device on the Russian site?  Photos or videos url link?
Thanks, Mike
I can't say as I don't even know where I got the document since I save some things and if they don't have a reference within the document I don't know.  Just was going through some things in the computer and found it in Russian and decided to run it thru Google translator.  I've seen reference here on OU to a number of Russian forums and I think if you dig around even in this thread you'll probably find some.  Just remember you can plug any web site URL into the Google Language tools section and get a translation of that page.
Bruce_TPU
Quote from: bolt on June 13, 2010, 08:34:33 PM
Still looking for "magic" spot frequencies. I say again its not important. OU can be tapped from Hz to Gigs. If not how do you explain a 1 ground OU device or groundless like the TPU? The fact that certain wave events occur at certain frequencies are not in themselves the source of energy.
What about air cap casimir dipole? No earth as Don Smith device operating frequency is Ghz. Wavelength is millimeters. Where is the source wave now?
Method to reach OU is pretty much universal despite operating frequency.
"Prentice got more out at 500khz." of course he did the higher the frequency the more joules pumped per second. Back in the day 500khz could always be achieved with relative ease by a spark gap but going over 1 meg or higher got a bit more difficult. This is why Don Smith uses 25khz NST's it high enough to do whatever you need off the shelf parts. If you want more power then step up the volts to 50kv or 100kv etc using coils. Now you have more potential joules the trade off is finding components that can handle extreme voltages.
@bolt
The TPU is ALSO frequency specific and dependant.  It will NOT work at just ANY frequencies.  You are wrong.  You spend a lot of time "dissuading" people from any ideas but your own.  Many of which are incorrect and based on pc hero syndrome and NOT posted experimental results.  I for one am tired of it.  If you are so ALL KNOWING by all means please build this device using your own ideas, and then post about it.  As a matter of fact, I know of NOTHING that you have built on this forum.  If I am wrong please post me to your working OU device.  Thank you and have a good day, user Bolt.
Cheers,
Bruce
kooler
hello all
i just noticed that you guys are building the same thing i was working on last year but a larger scale..
so i hope i don't mess the progress up here by posting this.. ..
i used 9-12 volts to get it rolling
and you need ac voltage in the secondary for cap discharging thru in the spark gap or you will never get the second transformer to run..
having the bulbs here will give you alot better light but will also reduce their life..
so if one bulb is to bright or over heating add more till normal or best feed back is produced..
i had this to self run for 38 seconds then quit..
but the reason i quit working on this circuit was my near death experience..
but anyway .. so i just stuck with 1.5-9 volts on this..
oh.. i never saw any kool stuff till i reached 1.6 khz- 8khz
good luck guys and girls
if you want to see my small scale look at my youtube vids
http://www.youtube.com/watch?v=HoLDlTv5YGw
vrand
Quote from: e2matrix on June 13, 2010, 10:59:14 PM
Thank you for the info.
Google Translation:
Forum for, alternative energo
http://translate.google.com/translate?hl=de&sl=auto&tl=en&u=http://mazeto.net/index.php/topic,1546.msg21626.html%3FPHPSESSID%3Dc8ec63sjlk07qb3i49fmonrhu3&rurl=translate.google.com&twu=1#msg21626
It has a lot of theories on the kapagen
Some YToutube, 10 videos here, with what looks like ferrite or ceramic magnet core:
MAD13.MOV
User: madsatbg,
http://www.youtube.com/watch?v=4v2uxVd3Mo0
Russian site 001-Laboratory
BTG Kapanadze as electrostatic machine
http://translate.google.com/translate?u=http%3A%2F%2Fwww.001-lab.com%2F001lab%2Findex.php%3Ftopic%3D455.msg10015%23+msg10015&sl=ru&tl=en&hl=&ie=UTF-8
Has lots of HV experiments.  The JLN replication info. has not made it to that forum yet.
Thanks, Mike
vrand
Quote from: romerouk on June 13, 2010, 07:13:54 PM
Many of the replicators here are only coming with theories, never tried it  practically .Easy to say do this do that but my way of thinking has almost nothing to do with  these theories.
Don't try to find a logic in what I did, just do it the way I did it. My logic in the most of the projects is different than others. Most of the standard ideas about free energy are already tested many many times before me, what is the point to be part of that many who failed. Testing new ways will bring us the answer in the right direction. 1.6kw load I thing it is  in reality somewhere around 900-1000w.I will make some more videos to make it more clear.I will plug all these bulbs in series connected to the wall socket and see the brightness then I will connect them in the circuit and see the difference.I will also try to take some scope shots as Stefan suggested.
Time is a problem as I have to go to work too, sometimes I am tired and the brain needs to relax. My day to day work is stressing me enough anyway.Also I don't want to destroy my neighbours electrical equipment with the radio waves coming from the coil.I've learned how to diminish the wave a bit now, isolating the spark gap.
In the mean time if anyone is replicating the project please just start 100% with what I have stated here then try to improvise.
Thank you again Romerouk for taking the time to do this experiment and then posting your results here!
Good to hear that you got your spark gap isolated.  I would be interested to seeing a photo/video of it when you get the chance.
Thanks, Mike
