0 Members and 122 Guests are viewing this topic.
ATOM1
TAKE MY EMAIL ASAP ! They will soon cut me out ! protoneutrons@aol.uk
They have a secret OU lab and are US government funded ! They take all the non patent tech copy it and sale it on to there government ....
Pass my email around asap I am uk government funded !!!!
ATOM1
PolandKapa
I did not build yet a prototype of the previous scheme. I have problems with the transformer 1: 1, the two tesla coils have a very poor performance. But after reading your posts I do not know that building this circuit has sense at all.
But i have an new idea, why not use the old passive circuit that works, and make it active to improve performance. Maybe it would require more modifications than presented on the scan, but it may be a good direction. And here would spark came in handy at capacitors to protect them from overcharging.
it's not a circuit similar to Kapanadze but may help in further searching.
ATOM1
There IS ERROR in ohms law and best to isolate it so you know why the tesla coils don't help much also why the radiant ambient energy tap ??? I don't see a need ...
I have 35 35v 22000 micro farad cap bank working my system coil ... No tesla coil ! I use a simple field dump armature coil from a 1kw AC generator to pass current through with a small 9000 v micro cap for spark and no leak on the current density just a zero point field pump ...... Its all about equilibrium of pressure ... The cap bank is set to harmonics over the octave scale in C ...................................
EARTH FREQUENCY IS IN THE KEY OF C ........................................ Just over 7 hz ect
This earth frequency is a field buffer for resistance in the system ..so no leakage ect than connect to transformer or transformers and best with magnetic DC arrangements for an increase in amps from the back emf from the load ect ... This way you can just keep building up the power output with magnets ....
All this ambient energy is a bit to much static over the spark not safe ...............................................................................................
Try and wind your own tesla coil on a 2.2inch plastic pipe its the vector for the curvature of the earth magnetic field make it this way and you tap the harmonic resonance field of the earth ect .....
Also try an open nickel coil one tenth mm wire but wind it as a spiral start the spiral at an imperial measurement not metric as all imperial numbers are harmonic scale ect .... set the spiral very carefully starting at 2.2 degrees and let it wind open up the 2.2 inch pipe . !
If you need more pressure in the system or volts ect it also is a very good solar trap coil .... its a little bit of magic that coil ...................
ATOM1
ATOM1
I love the pic wow ! Where is it taken ????
Now don't waste a moment with all the crap trust me son just get the 35v 22000 micro caps £150 for 35 of them line them up in rows of 7 and connect each one to the first one in the line of 7 ! The length of wire will be longer for each row of caps ! Each cap will have a stable eq at 25volts ... But watch what happens to the volt rise also this cap ..TAKE IT UP TO 200 VOLTS NO MORE..
Buy a cheep 1kw ac generator and take out the core that's your field dump oscillator stay at 100 hz that all you need ! build up the transformer around that with extra magnets no neo magnets needed just cheep ferrite ones ..... feed out to earth before the load very important for a feed of free electrons from the ground .... ok ...
stay clear of the spark put it in a safe box one touch from that it could kill so don't mess with it ........ find your point of unity with the cap bank and the armature coil ! and the 9000 v cap spark but this spark will be much higher than you think be safe son ...!
lots of ways to amp it all up but don't increase the volts just the amps ,,,,
Good luck
