0 Members and 129 Guests are viewing this topic.
stivep
Quote from: magpwr on July 13, 2015, 02:49:17 PM
Dear Wesley,
I don't suspect any radiation poisoning at all since only one of you faced hair loss problem.But i would run not walk away from this side project if both of you faced similar hair lost problem after standing in close proximity while yoke in operation. ;)
For your prolong headache case i merely suspect it's just a case of "lack of sleep" coupled with high caffeine intake in order to optimize your time spent in Lithuania.
Final justification -We don't see Akula getting balding problems with yoke.Hence no radiation issues.
After your lengthy explanation it does make  sense now why the team which you were involved in went silent for a long long period.
Thanks for the reply.
You do own high end equipment eg:Spectrum Analyzer,Function Generator and etc  because of TK.
Now it lay dormant is it because of fear of " wrongly suspected" radiation poisoning from  yoke and after which involved in Colman experiment which does release real "poison" if it is functioning.
It is much deeper that that.
The  only way to defeat "any side effects" in this area  is time.And only if permanent damage is not yet present,
That is why say X-ray can only be taken x  amount of times per year that is being called a dose.
Shortly  after that I got involved with Colman.
I was able to assign some of phenomena as common for both, the yoke Lithuania experiment and Colman.
But that made  it even worse.
Summary dose than  needs to be calculated not only based on observed phenomena but on energy levels of specimen that is  giving out, photons/particles.
So by that one has choice to go into it like uneducated guys in Chernobyl disaster send to clean up area, attracted by some rewards and authority orders,
or just simply seat and start to  think.
The next step was to get a grab on sophisticated equipment in that area of physics, and get familiar with  processes that might be of value.
That is the lengthy road. Equipment  is very exotic and science behind is very much time consuming.
In particle physics experiment is just the last few percents of that time. Mostly that is conformation of  proper assignment  to the  area of already known  science.The discovery can be made as to an origin and transmutation chain but that is about all.
However that is what is mostly needed  to start to understand it.
The expense of  the equipment is just related to "opportunity factor."
Yes one may move forward like Ruslan did.
That is one way of achieving a goal.
Talking about opportunity it is like:
"You see it now, just take it,, as there is no other buyer, it is going to  be trashed or buy new for hundreds  of thousands."
And if you do not take it you may wait another  year  just for  one special cable that cost 1350 before tax that is in front of you now ( you just do not know that  you will need it for device that you  did not buy  yet)
So what that I bought DigiDart for almost nothing.
Next what  is needed  is software and that is  very expensive...Can be only acquired from manufacturer.OK I have got it.
and next is Dewar
and next is HPGe
and next is HV power supply regulated and with cutoff circuitry that works with particular equipment.
and next is $73 every time you put LN2 into it till it evaporates every two weeks, however if Dewar is small portable ( beauty)
than one time filling up, is good for few hours of work  only (with  4 hours wait time to cool down to 77K.) Initial cooling down wastes  most  of LN2 .
So another task just make or buy your LN2 generator. Guest what, that is not  available any where, not in auction, not in ebay ...
The most inaccessible item.
New one ,sure you can buy, - (it is my contribution to the science I do not beg for money.)
another  way is to  use  scintillation detectors NaI(Tl).That does not require LN2.
I have it, but  pick recognition that is related to efficiency  and energy of specimen ( resolution) is  far from  what  HPGe  can do.
Yeah  it would be good to have portable lab in one instrument Inspector 1000.
Nice, but from different manufacturer and different software and calibration standards.
I forgot already  about using good and reliable however again scintillation based Ranger.
Now I got involved with sexy equipment..  yeah..... small beauty fragile and  like : do not touch me I'm so beautiful.I'm portable but do not take me to the field I will  have scratches. Yeah I'm going to give you neutrons as well  I'm Inspector 1000.
I need something perfect.................
yeah  get it.
Detective EX. and it is HPGe no LN2 some mechanical vibrations .e,,,,eeeeeeeeee  OK
Wow this is perfect.
Yeah it is perfect but heavy like horse, bat life 3 hours after 12 hours of mechanical cooling.
I got it I'm so happy......................
By the time I get to lab I lost already 1.5 hour.
By the time I start experiment there is another 12 hours of cooling and charge.
And yet there is another  piece of software  that works with that device but  for 6k.....
So OK  I have  Detective EX now.It is the best thing I have ever had.
Just must to wait  to get some additions...........
So why  I need to use  NaI(Tl) now ...... for  what? ??? ?
To see nuclear response?  only with Gammas?
I have seen it  already.
I need to know what I'm dealing with in specific.( alpha,beta, gamma x-ray, neutrons, positrons," negatrons"- betas   say all antimatter)
I have most of it.
But not all of it.
Most of you guys are  so much preoccupied with your personal life.
I respect your wishes and your involvement.
However in the big picture nobody gives  Sh.t about me.
the only one common  point between us is to  get a good grab on FE.
What you  do  with with it after that, is  completely personal.( disconnected movement of individuals  no sorry , no pardon)
So let me do what I can. At the end  everyone will have his own chance to make  his own few bucks.
Do not rush me, I'm more interested in  mechanism than  just application.
As long as I did not waste my life I'm still of help same as many of you.
Wars will start after  technology is widely present world wide.
Wesley
stivep
Quote from: madama on July 13, 2015, 05:03:22 PM
there is cool ln2 maker here
http://www.instructables.com/id/Homemade-liquid-nitrogen-generator/
btw why do you need the ln2 for?
No my friend this is BS.........
It is like you put water to your gasoline engine while 50% of it is still there.
You need 99.95% steady LN2 no  liquid air............
By the way read my article again I made some additions.
Wesley
core
Quote from: madama on July 12, 2015, 09:49:33 PM
you realize that becoming senior is just a count of number of posts?
i ve sent a pm by the way
You misunderstood. I was a regular on this thread some time ago. It's been about 2 years (or so) since I have posted.
So his comment was not in reference to post count but to the time I spend trying to solve this.
Thanks for the update Wesley.
-Core
stivep
Quote from: core on July 13, 2015, 07:52:48 PM
-Core
I was thinking about best possible answer and I found out that my previous response have not been  up to the question asked.
Quote1.Hear loss....
Gamma  radiation is ionizing radiation. It ionize  DNA, affecting RNA.
Photons  of gamma passing through a medium ( human body) are being absorbed.
Although DNA tries to replicate itself (e.g cuts on your hand are healing) sometime  DNA is cut on half and that it rebuilds itself not in the " right  way"
One of theories  based on statistics stands that time is needed for  that  energy to be dissipated.
However statistics are  not accurate and based on number of people with  post radiation symptoms. (e.g leukemia)
The truth into it is that  for some individuals UV on the beach is cancerogenic  ,
for  others  medium- high dose ( in short time )of Nuclear reactor radiation is not .
UV however has  significantly low energy level EM radiation.
( energy: is another way to express frequency of Electromagnetic wave)]
So for low range  EM radiation( electromagnetic waves)  expressing  EM in meters or Hertz  is practical.
( - the wavelength... say 80m = 3.8 MHz or 23cm=1.2GHz )
For frequencies of Electromagnetic radiation such  as  visible light  and  UV ( ultraviolet) it is more practical to express  it in  wavelength only.
visible light spectrum is:
390 to 700 nm.
In terms of frequency, this corresponds to a band in the vicinity of 430–790 THz.
Our eyes are perfect  EM  receivers there.
Starting from X-rays it is mix of opinions but mostly  keV  is used to describe   EM radiation.
Thing to remember is:
All electromagnetic waves  have  means of measure
-energy,
-wavelength,
-frequency.
https://en.wikipedia.org/wiki/Electromagnetic_radiation
Me being cautious with ionizing radiation: it is   my  voluntary manifestation of   me going over the  statistical boarders , in believe that I know what I'm doing now.
And most  from  billions of people around me are simply uneducated, careless, ignorant or not interested in that  area of physics.
Nothing wrong  - majority sets the rules of perception . Not me.
Wesley:
My slow down with Colman experiment  is due to lack of sufficient amount of money  to buy equipment
right from the shelf and 1 week from now give you safe and ready to use  FE device.
Lead acid battery  is for me more contaminating  environment  and unsafe than Colman.
https://en.wikipedia.org/wiki/Ionizing_radiation
If I was to give rough estimate of number of people  having particle lab I have in the world                                    it would  be around   1000 per billion.
If I was to give rough estimate of number of people  having particle lab I have in the world with my level of income  it would  be around   10 per billion.
If I was to give rough estimate of number of people  having particle lab I have in USA         with my level of income  it would  be around   10 per entire US population
that is how exotic that  field is.
Summary:
Radiation damage  I  see as  and time  needed  for organism to be able to recover ( regenerate) from -ionized energy absorbed and exchanged to  heat or damaging factors of that radiation to  DNA ,RNA
Wesley
PS: Right below there is Lynx MCA ( multi-channel analyzer )
It goes from 0 eV to gush,,,,,, I do not know.... to very high  MeV region.
