0 Members and 177 Guests are viewing this topic.
romerouk
Quote from: xenomorphlabs on June 14, 2010, 12:51:44 PM
Romerouk, that diagram came up on the russian site 001lab.com. It is NOT from Kapanadze, but some forum member. There is literally 5-10 new diagrams popping up every week in the various forums and the one you posted is
as speculative as the hundreds of other diagrams, no working device was built from it.
@Stefan : It sais in the diagram that the upper oscillator or Generator Block as he calls it (for the inverter basically) is running at 50 Hz.
It´s an interpretation of SR´s device.
For me this circuit makes sense and is quite easy to build, I will give it a try.I am happy to hear that JL Naudin is going to post a 12v circuit, I am working on a 12v circuit too.I had to cut the high voltage windings from a MOT and I created 2x12v circuit so I can use it in reverse as  an inverter.Originally I tried to cut the 240v winding and use the 12v in with the high voltage out but it creates sparks and destroyed the transistors after few attempts.
bolt
Quote from: hartiberlin on June 14, 2010, 01:09:29 PM
Okay, and at what frequency is the lower left High Voltage oscillator running ?
Many thanks.
Due to the ciorcuit diagramm, both oscillators are NOT synced...so I wonder
why the 50 Hz oscillator is needed ?
The HT supply looks like a colpitts and free running. Its very low powered. Small caps on the feedback its going to be hi Khz.  If this circuit is true which i doubt it totally as its another "idea" of kapanadze from Russian forum member then the HT  "LIFTS" the potential of the circuit as a joule pump and is modulated on top of the HT by the fet driver. Presumingly some says its 50Hz i suppose it could be the timing cap and res support 50hz operation.
So 50Hz will come thru to the o/p.  The odd thing about this circuit is the HV used as carrier and Low frequency modulator concept is fine but they should be in sync to provide parametric amplifier lock and shut off return CEMP loading. The 50Hz then also acts as a quenching circuit  in series with a tuned circuit like a super regen. Alike a super-regen the quench frequency is SEEN on the o/p which is basically what you want. ..its pretty clever anyhow.
Assuming a lock is NOT required this circuit can be modularized using standard NST for HT and small inverter to provide the FET driver stage greatly simplifying building.
Ahh thats better!
xenomorphlabs
A sine/pulse inverter feeding a ferrite-ring-cored coil with an underlying HV winding has been tried numerous times by multiple experimenters from russian forums with no success.
So it´s either a very special frequency which Bolt repeatedly excluded to be the cause or an unusual winding interconnection that boosts the current somehow. Anyone who replicated this kind of approach (even synced) was underunity.
If it was that easy, at least one of the experimenters would have seen a gain.
For example these guys experimented with crazy alex´s diagram that Romerouk posted : http://www.youtube.com/watch?v=7UqFvij2yk8&feature=player_embedded
bolt
Well if its been tried to exhaustion better scrap the idea then and stick with a raw Kapagen and just tweak it so it runs a bit more comfy. After-all just ONE OU watt is more than a billion other people have achieved.
Acca
Enclosed is a link to A Russian forum that has schematics and ferro coil for the Kapanadze device in high resolution...
http://next-energy.2x2forum.ru/forum-f1/tema-t7.htm
Al...
