0 Members and 148 Guests are viewing this topic.
bolt
Quote from: Acca on June 14, 2010, 03:09:16 PM
Enclosed is a link to A Russian forum that has schematics and ferro coil for the Kapanadze device in high resolution...
http://next-energy.2x2forum.ru/forum-f1/tema-t7.htm
Al...
Acca thanks but they are ALL speculations. Only SR has replicated kapandaze and he is keeping it a secret so no one else knows till its rebuilt and youtube video goes up with full disclosure its still a mystery and no "official" circuit exists.
the_big_m_in_ok
Quote from: xenomorphlabs on June 14, 2010, 07:53:45 AM
It has, i have posted there Naudin´s power comparison image for instance:
http://www.001-lab.com/001lab/index.php?topic=4.msg13312#msg13312
Also others DO discuss it there.
These forums have been linked to already from here numerous times.
I tell you, most of the info that you are googling together is already in THIS thread here, really ;) Just go through it from the middle.
@all,
xenomorphlabs has a point.  More than enough circuits covering Tesla's and Kapanadze's work.  If you think you need to, you can find a Russian-English translator program on the Web.
--Lee
forest
That Russian circuit is good, but ferrite is not needed,better is soft iron or stainless steel IMHO
Groundloop
@All,
Here is something I discovered while running my small setup.
The oscillator output is AC. The oscillator maximum output
is approx. 5 watt. Normal output is approx. 2 Watt. The coils
is insulated from each other. I get no light in my bulb until
I connect a wire between A and B as shown in the drawing.
My only grounding is a aluminum plate that everything is
mounted on. Circuit is not OU but demonstrate an interesting
effect.
Groundloop.
bolt
It is interesting i presume as its not HF there is no magnetic coupling unless you include a core.
