0 Members and 248 Guests are viewing this topic.
Hoppy
Take no notice of the crazy meter measurements. The clamp meter was all over the place and we don't know what frequency was being measured, so the accuracy of the meter is questionable. Yes, 1000W rated bulbs but 1000W dissipation or even close, no way.
The supply cable was hidden in the green box video. The bearded man held the secret.  ;) The earth wire may or may not have been used as a return but probably was.
The Aqua2 earth braid was probably used as the supply return but there could have been two very thin insulated wires inside the braid - two sides in one.
Lets just leave it that we have different opinions and none of us on this forum know the truth, which will probably go with Tariel to his grave.
PS. I'm sure that a few of us on this forum could set up a similar green box demo, given that a good many of Tariels audience were most likely in the know.
PolaczekCebulaczek
in Wesley Kapanadze garage video we can clearly see a transparent insulation wire connected to metal car repair pit ,so 2 wires hidden in one theory in unlikely to be valid,Wesley inspected the device well, but why this garage version was only producing 200 watt? why not 3-4kw like the green box? Wesley can you tell us how much did you pay to Kapanadze to see this miracle? in case on NMR ... where is the nuclear radioactive rubin tv yoke? in the white box that's on top of this garbage with fake pcbs?
verpies
Quote from: PolaczekCebulaczek on January 26, 2016, 01:32:21 PM
in case on NMR ... where is the nuclear radioactive Rubin TV yoke?
In his latest video Wesley was not writing about any TK's devices in reference to yoke cores in Lithuania experiment #1 and Tiger's subsequent experiments.
Also, a material does not have to be radioactive to undergo NMR.  Example - Hydrogen.
I have corresponded with Wesley many times and it is my opinion, that with his electronic experience and "street wisdom" about those parts of the world, it would not be easy for TK to deceive him.
People should be grateful for his translations and other contributions.  There is no reason do doubt his integrity, either.
forest
"I charged the condenser with 40,000 volts.  When it was charged full, I discharged it suddenly, through a short circuit which gave me a very rapid rate of oscillation.  Let us suppose that I had stored in the condenser 10 watts.  Then, for such a wave there is a flux of energy of (4 x 104)[/size]2, and this is multiplied by the frequency of 100,000.  You see, it may go into thousands or millions of horsepower."[/size]
[/size]
"You see, the apparatus which I have devised was an apparatus enabling one to produce tremendous differences of potential and currents in an antenna circuit.  "[/size]
[/size]
The only missing part is to tap the energy in antenna without disturbing it.The excess energy is damped to ground via spark. The antenna is of course not radiating one, probably full wave.[/size]
It is just radio technic, nothing new.[/size]
cheappower2012
To Hoppy
You said,"Take no notice of the crazy meter measurements. The clamp meter was all over the place
is questionable.
Yes, 1000W rated bulbs but 1000W dissipation or even close, no way."
The frequency was measured, it was 49 Hz,also the transformer with bridge rectifier
would not work if the frequency was too high to loop the device,
well at least you believe the bulbs are 1,000 watts that's progress,LOL
You said,
The bearded man appears mentally challenged,never the less,lets say its fake.
First step is whats the inputs and outputs of the box,figure 1.The black
cable is internally hooked to the other side,this known by viewing the video.
The lights are lifted so theres no hot wire anywhere,because the black cable is disconnected at one point you need
a ground with a switch and a hot side hooked to a switch.When the bearded man grabs hes nuts
he sends a signal to another person who then throws the hot switch and throws the ground switch,
or just the hot switch.
If the ground cable is grounded only the
hot switch is thrown,if the ground cable is disconnected,then the ground switch
is thrown along with the hot switch.Of course which side of hes nuts the bearded man
grabs determines whether only the hot switch gets thrown or both switches.
And then we have free energy,now can a hot connection wire and another solid ground wire be found in the video no,
then its a David Copperfield trick.
There is no connection to the blue wire going to the green transformer,
unless you can show a connection that's not how its done.
The point is,is it possible that Kapanadze's devices are real I think so,is it possible its  fake also possible,however  my belief is that
the odds are greater it may be real.Until enough information is gathered to
attempt a real replication it will be like, did we go the moon or is that a hoax,or did the government plan 911.
