0 Members and 99 Guests are viewing this topic.
Void
Hi Wesley, T-1000. Can you guys confirm that when you were lighting the 150 Watt bulb
in your Lithuania experiment using the yoke core, that you guys were only driving
the yoke core with two USB signal generators? You weren't using any other higher power
generators than just the two low power USB signal generators to drive the yoke core? Also, was earth ground
connected to one side of the 150 Watt bulb to get it to light up?
Also, what were you using for the earth ground connection?
stivep
Quote from: Void on February 09, 2016, 02:09:07 PM
In yoke experiment there have been only two generators  connected with effective signal  output  power of 1W from each one of  the generators.
However after impedance mismatch the   effective power  in range of milliwatts  was  delivered to the windings.
We have not have per say ground wire  connected  however body of the   experimentator  was acting as  a ground ... to be more accurate  counterpoise.
As far as ground wire:
In nature everything is trying to get to equilibrium.
It could be compared to  the balance  ( weigh scales)
If resonance circuit is loaded with  a  dipole antenna than every antenna needs    counterbalance called also counterpoise
with walkie talkie it is your body
with car antenna for FM radio  it is  metal body of the car.
With antenna on  10th floor of the building it is metal plate  below the ground plane antenna and so on.
in horizontal dipole  one arm  is the counterbalance to the other  and reverse in  lower part of the  cycle.
For the new concepts of cellphone there is smart microprocessor  rebalancing if the phone is in your hand or on the table, however mostly manufactures do not care.
the Cell is about 1 mile away so mismatch of impedance does not count  that much.
there are plenty of other examples, however  artificial ground is  comparable to  real ground.
That is part of the story  the rest  of it  is in my video
For more accurate information please  turn to T-1000 . He is the real brain behind it not me.
Wesley
Void
Quote from: stivep on February 09, 2016, 07:13:30 PM
In yoke experiment there have been only two generators  connected with effective power of 1W from each one of  the generators.
However after impedance mismatch there   effective power  in range of milliwatts  was  delivered to the windings.
Hi Wesley. Ok, thanks for the info. I just wanted to make sure because T-1000 mentioned a 9V, 1A mains transformer was
used, so I wanted to make sure that it wasn't connected to the mains, but only used for impedance matching between the signal
generator and the 15 turn winding. Also, T-1000 said he thought you guys were always using a ground wire when you were seeing
the 150 W light turn on, so I was wondering what you were connecting the ground wire to...
verpies
Quote from: Void on February 09, 2016, 07:32:18 PM
As far as I remember, there was no ground wire connected to the yoke device when lighting that 150W bulb.  Just the operator's hand until a longer counterpoise was connected.  See the video time index 10:06.
Also, later I think that when they blew up one of their USB generators and were waiting for the replacement, they used the 9V mains transformer as a 50Hz sine signal source.
Void
Quote from: verpies on February 09, 2016, 08:37:21 PM
Hi Verpies. Thanks. Yes, I had seen that part in that video, but T-1000 had mentioned that he thought they
always required earth ground to get the light bulb to light. At any rate it appears synchronization of some sort
was also required between the two signal generator signals as T-1000 wrote here:
http://www.energeticforum.com/164613-post28.html?s=194d7739ca54847a7cfe3c15918da88d
http://www.energeticforum.com/165262-post62.html
http://www.energeticforum.com/165188-post51.html
After reviewing some of the former notes on the setup and tuning, I think I will set this project aside now due to their
being too many 'unclears'.
