0 Members and 119 Guests are viewing this topic.
Hoppy
Quote from: cheappower2012 on February 16, 2016, 09:55:25 PM
People don't get just how devious Tariel is,he says things untrue because he knows that people will focus on them,there red herrings.I can't get a certain this or that,people grab and run with it.Tariel and SM inventor of the tpu think the same,fake out people looking to replicate there devices.
Tariel's prime motivation was / is to financially profit from his devices. The wish to make money and be acclaimed motivates the magician to produce ever better tricks to capture the attention of his audiences. Tariel IMO thrives on creating the perfect illusion whilst utilising what anybody trained in electrics / electronics see as an absurd collection of props to provide intrigue and character to his stage area. Hidden within them lies something so simple you'll laugh.
Zeitmaschine
Quotesince its impossible that it could work
This is also true for the drawing below (Patent US6104107).
The secondary L2 of the high voltage transformer (Alternating Density Generator) does not form a closed electric circuit, hence it can't generate a magnetic field, hence there should be no counter EMF in that transformer. Nevertheless an oscilloscope connected to coil L3 measures clearly some sinusoidal voltage, meaning, the coil L4 must generate a magnetic field somehow. Impossible?
Not according to my experiments. Although a capacitor in parallel to L4 is necessary in order to work at the low frequency of 50 Hz (not 1 KHz to some hundred KHz as mentioned in the patent). The capacitor and L4 must form a resonant LC circuit at the frequency of the AC source (this corresponds to the 3-phase parallel LC circuit in Stepanov's carpentry setup).
Here connection Bx6 would be the point where Kapanadze put the clamp meter between in order to measure the (impossible) ground current. So far my meter shows nothing, but then, where is the energy coming from that generates the magnetic field through L4 (also open)? Obviously not from the AC source because the open L2 can't generate any counter EMF.
What's missing here? Is it perhaps the simple frequency doubler circuit like seen in the Stepanov's cardboard box setup in order to get a special resonance?
Just something to think about ...
captainkt
Hi Zeit, 250 volts is not enough, increase voltage to 3,500 30,000 or 50,000 and make conductive body the earth then current will flow readily through coil 4.
So simple it will make you laugh.
Keith
Hoppy
Quote from: Zeitmaschine on February 17, 2016, 07:30:35 AM
I think this is a possible modus operandi using a high voltage source. What I'm sure of, is that the braided lead on the aqua2 device carried the current to supply the device and that no free ambient energy was involved in running the device.
leo48
From an observation post 22224
(Each of these three individual trasformers can provide 2 KW of power?)
- No! the transformer according to the indications of a user can have up to 300 W total
-and taking into account the resistance of 78 ohms with which the thread is made the transformer
     winding the output current is 0.5 A to max
-It must also take into account also that the transistor KD502 has a maximum voltage of 60V operation
     and an energy dissipation of 150W
Then amplify the power is either the blue coil or something that is inside the tube, actually seeing
a toroidal coil and a cylindrical some other yellow but what is?
Perhaps one day we will discover how it works ..
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
