0 Members and 119 Guests are viewing this topic.
Zeitmaschine
What is electric (ground) current? In order to measure an electric (ground) current by means of a clamp meter the electrons in the wire must generate a magnetic field around that wire. Otherwise the meter will show nothing.
So how to accomplish this without a closed electric circuit? This is the main question here!
In Stepanov case (image to the right) the only way to fake that ground current (here the battery is the conductive body) would be to tamper with the inverter - namely creating a short between the 12-V-in and the 220-V-out side within the inverter in order to have a closed circuit.
But then the question comes up: Why should Stepanov showing a fake ground current without good cause? Why unnecessarily faking a ground current? He could claim more energy out than in easily without showing that ground current.
This question stays unanswered.
By the way: What things could happen if we connect two different coils of a 3-phase transformer to two different frequencies, like 50 Hz and 100 Hz, phase-locked to each other? Anyone tried? :)
leo48
I tried to mix two different frequencies square wave
in a transformer to the primary I sent to a head of a frequency and all 'other end of the other frequency and the result is on the secondary however, the output power is less than the entry.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Hoppy
Quote from: leo48 on February 17, 2016, 11:09:09 AM
From an observation post 22224
(Each of these three individual trasformers can provide 2 KW of power?)
- No! the transformer according to the indications of a user can have up to 300 W total
-and taking into account the resistance of 78 ohms with which the thread is made the transformer
     winding the output current is 0.5 A to max
-It must also take into account also that the transistor KD502 has a maximum voltage of 60V operation
     and an energy dissipation of 150W
Then amplify the power is either the blue coil or something that is inside the tube, actually seeing
a toroidal coil and a cylindrical some other yellow but what is?
Perhaps one day we will discover how it works ..
Leo48
Yes, the trafo is likely just a bit of eye candy, like most of the rest that's visible.
captainkt
Hi Hoppy, I heard that when load removed spark speeded up then slowed under load. Also heater stayed on when earth was disconnected, but I do not know for how long earth was off.
Keith
Hoppy
Quote from: captainkt on February 17, 2016, 02:02:05 PM
Keith
Hi Captain,
Yes, the video shows the spark speeding up under load. As for the the heater running when the braid was disconnected, this was not demonstrated in the video, so we have no way of confirming this.
