0 Members and 139 Guests are viewing this topic.
verpies
Quote from: Meta on March 16, 2016, 12:16:45 AM
I once saw a electron microscope micrograph of a matrix of atoms. There were no cloud of electrons around a core of protons and neutrons. As I said, all things are nothing more than spinning space called Anu or the basic unit of creation, the torus.
Like shown here and discussed here.
In an atom we just have clusters of toroidal spheres.
As shown here.
...but this is not a thread for discussing general theory of reality.
This is a thread for replicating specific FE devices and most of its users are still stuck in the realm where atoms (matter) exist in a container of space (or aether) ...like fish in a fishtank.
NickZ
   Verpies:
   Yes, but, some others of us here are concerned about what is holding that " matter" from dissolution.
Or what brought it together to form what it did in the first place. Cosmic unseen fields, perhaps.
  Where does the energy come from, that a magnet gives of. The atoms, or the field that it's in?
   We need to know the real source, of magnetism, as it is the cause of electricity. Or not?
   Got you thinking...
verpies
Quote from: NickZ on March 17, 2016, 02:57:54 PM
   Verpies:
   Got you thinking...
Not really.  I found answers to all these questions ~15y ago at the website to which these latter links lead.
Discussing these theoretical matters is fine but not in this thread unless you can show direct applicability to TK's devices.
Also, since when are you considering the liberation of energy from decohesed matter?  I thought that you were a believer of energy from the "ambient", "aether", and the like...
P.S.
Do you realize that every time you write "field" this is a colloquialism for a "force field" ?
Meta
"most of its users are still stuck in the realm where atoms (matter) exist in a container of space (or aether) ...like fish in a fishtank."
________________________________________________________________________
If you build a system that is closed, like a fishtank, it will not reach overunity. Open the tank to the 4th dimension of space which is the source of all energy and consciousness. To open it, just usde a dipole (battery with two terminals). Now your circuit is open to all spatial potential.
Meta
  Verpies:
1. Yes, but, some others of us here are concerned about what is holding that " matter" from dissolution.
2. Or what brought it together to form what it did in the first place. Cosmic unseen fields, perhaps.
3. Where does the energy come from, that a magnet gives of. The atoms, or the field that it's in?
4. We need to know the real source, of magnetism, as it is the cause of electricity. Or not?
Got you thinking...
1. Spiraling space is implosive, center seeking......the matter in the center of the toroidal spiral, we call matter. The movement of spiraling space toward the center of matter, we call gravity. Its just compressed space (information). Here's a spatial formulae that shows that space has the golden ratio within it, v2/c2 = Phi. Phi spirals have the ability of infinite information (compression). All matter is surrounded by spiraling space in the form of a toroidal field. Some scientist said that there are at least 21 fields in space.
2. The 21 fields of space work together. Its called the Hidden Order. Science calls it Chaos which means Hidden Order. We call it Sacred Geometry.
3. The magnet and magnetic fields are just one of the 21 fields of space.....space is always the source of all field energy. Atoms have no energy as source.....atoms are just the solid trash collected in the centers of spatial vortexes. Magnetism and electric fields are low level forces.....there are much higher fields and forces which Im showing you how to access and once accessed we then step the energy back down again so we can make a overunity machine run.
4. Some say magnetism came first, some say electric came first. Im not sure which it is, however, electric fields are always 90 degrees out of phase to magnetism, and gravity is 90 degrees out of phase to E and M. This means they are all in different dimensions since a dimension, in science, is defined as a 90 degree rotation of an electron. Concerning just E and M, they work together like a bird flapping one wing and then flapping the other wing, 90 degrees out of phase, like a crippled bird, flying.
Nevertheless, all these force fields are merely the close packed spatial spirals we call toroids...ancients called it Anu, or spinning space. Now Bucky Fuller says these tiny spiraling toroids are so small, so jamb-packed that "space is 960 million times as dense as steel". This means that space is packed to the hilt with the only "tiny little thing" that exists....the uncountable spirals of space, called tori. There is nothing else in all space or matter.....matter is just compressed space. This tori acts just like a gyroscope.....disturb the precessing axis and the matter (electron) moves out of its matrix hole, rotates 90 degrees to the disturbance and spirals around and down the wire as electricity.
