0 Members and 276 Guests are viewing this topic.
step4
Question :
- why in every kapanadze device there is inverter 12vdc to 220vac lying around?
- someone notice that Amp clamp going crazy over tesla HV HF?
- WHAT IF?, kapanadze devices only get's the Amp only from influence of HV HF?
sure no need to reduce the HF since 200vac came from 50Hz inverter.
2004 video kapanadze HV HF is inside CAN , with 2 transistor+2 resistor as pulse,iron cored
Tesla 593.138.
Simple huh?
captainkt
Hi step4,
So all that is needed is a rough voltage/current/frequency out of device to charge battery and use inverter output to pull off smooth 240 volts 50 hertz for everything else.
Keith
step4
All we need is how to understand this part:
Kapanadze statement from galaksija forum,
4. secondary output coil is bifilar coil Teslova
from which one part is used as a closed
magnetic circuit (most likely a resonant
capacitor) and the other is loading. It is also
grounded at one end of the load.
when kapa say "closed magnetic circuit" my insting sez that is not an LC form,but truly closed circuit coil only
in green box show the goverment guys put amp clamp to GROUND cable and its show 23 for 5 lamp attached, why GROUND show such big Ampere?false reading? i don't think so.as i remember kapa device need ground from (earth).again i believe it's related with that Closed Magnetic Circuit(CMC).what i'm trying to say is that CMC (IN RESONANCE MODE to primary) connected to ground earth and not to fasa line.
CMC = CURRENT AMPLIFIER ? Patent WO2008103130A1
Fasa line from HV HF connected in parallel with fasa 50 hz from inverter.
Green box video :
Kapanadze : Likely "CONDENSER INFLUENCES"
tagor
Quote from: step4 on May 29, 2016, 03:48:35 AM
before posting , learn how to rezise pics
