0 Members and 145 Guests are viewing this topic.
Zeitmaschine
Quote from: cheappower2012 on November 07, 2016, 05:16:17 AM
Why would you believe the patent is even real,Kapanadze is faking you out.
I think it is semi-real, because if we look at it closely, then the Kapanadze patent resembles also the Stepanov device. That's a strange coincidence.
If one wants to connect a high voltage three-phase transformer and by mistake one of the transformers is connected through a diode bridge and a capacitor, then the high voltage output would be 50Hz and 100Hz (60Hz and 120Hz), which could result in a very odd behavior when at the same time a feedback loop is formed somehow.
Basic (Kapanadze) principle: Parametric resonance including a high voltage part.
Still missing: One or two(?) capacitors (Kapanadze calls them filter or adjuster) and the proper connections of the high voltage coils.
a.king21
To Everyone, It is with the deepest sorrow that I have to announce the sudden and unexpected Death of John Bedini today (Saturday, November 5, 2016). Those of us who knew him well are without words at this time. Anyone who would like to leave a comment here about this truly brilliant and generous Soul, please do.Peter Lindemann http://www.energeticforum.com/renewable-energy/20629-end-era.html
http://emediapress.com/2016/11/06/john-bedini-you-will-be-
R. I.P.
Zeitmaschine
Quote from: a.king21 on November 07, 2016, 08:21:57 AM
My warmest condolences.
A death by natural causes or related to free energy research? :(
cheappower2012
Zeitmaschine
Don't you have con-men in your country,LOL,you need a source of energy.
This is like creating anti-gravity,grab your ankles and lift yourself off the ground.
You can not defeat conservation laws,it requires an unknown energy source,for any
real world free energy device to work.It would be an energy converter,since energy
can not be created or destroyed.It very possible that Kapanadze may have discovered
unknown principles,that he keeps secret.Without knowing how the new principles
work,eye balling the device ,and applying conventional principles has to end in failure.
Zeitmaschine
Err ... I thought we had figured that out a long time ago; the hidden source of energy is the aether. What's the problem with that now?
Of course, we should stay on established physical principles as much as possible. If Kapanadze has discovered an unknown principle, then I can't see any reason why someone else shouldn't be able to discover that principle as well. And I'm sure it's not related to high tech.
Bearden says the energy comes from the fourth dimension. So we just have to tap the aether in the fourth dimension. Sounds easy, doesn't it?
