NRamaswami
Thanks for your kind words. It is always motivating and encouraging to receive good words.
I suspect that today Figuera device is very easy to do. It is basically create a powerful magnetic field using AC input and take output as pulsed DC to merge current and increase the voltage uniformly. But who will look at simple things. I can only confirm that a very powerful rotating magnetic field can be created easily with very low AC input to magnetise very large iron core. We would need to use very thick wires if we are going to take output as pulsed DC. That's is quite expensive to test and quite difficult to wind. But it is fairly simple.
darediamond
Quote from: cliff33 on April 15, 2018, 10:20:33 PM
Hi Darediamond,
Some time back I think it was you who said that to get maximum magnetic strength from a solenoid coil, it should
be wound trifilar or more and than connect these wires in series.
Sounds reasonable, but I just wanted to ask you if you yourself have tried it or is it just  theory
you read about?
I talk and walk the talk Cliff33.
As for Figuera Modern day replication, apart from applying Multifillar wire, you need Resonance to make it work properly. And to reduce cost, apply High frequency. Place your serially connected ac-powered resonance opposing coils in Oil. At resonance, Lenz or Ohms law is negated.
NRamaswami
The only device where I have seen and any one can replicate it of a possible COP>1 is in Ramaswami device which is a variation of the Figuera device. Input used was AC.
Primary was multifilar coil and secondaries surrounded each primary coil and were wound on core. The output of secondaries on both sides of primary is almost 98% to 99% of input. Some times it appears to be higher but it is treated as measurement error.
Secondary was also wound on the central core as in Figuera. Even with two primaries I was able to add five secondaries like this and the combined output of all five secondaries taken separately is cop>1, But it is not sufficient to enable a self runner.
I have tried multiple times to make a self runner but it does not work. It has been strongly indicated by a very highly reputed Scientist that resonance is key but I'm not able to invest my time, money and energy on these things any more.
Out of all devices that I tested only the Figuera device type of device having a common core has any potential. I'm not able to understand how Nelson Rocha device works and how the Tariel Kapanadze device works.
v8karlo
http://amasci.com/tesla/tesceive.html
http://amasci.com/tesla/tcvmail.html
From the article:
We see that by putting a big AC voltage on the tuned circuit and by adjusting
its phase in relation to the tiny incoming current, we can "suck" the E x M wattage
from the enormously broad wavefronts of the incoming waves.  It also works this
way inside a simple circuit using conventional voltage dividers: add a resonant circuit,
and the series impedance of the power source behaves smaller.
See this example circuit. It should still work this way even when a part of the antenna
circuit contains a series capacitor whose dielectric is made up of many feet (or even tens of km)
of empty space.
It's very much like building a high-voltage power line: to transmit high wattage on a thin wire,
we use high voltage at low current, and then we put a step-down transformer at the far end of
the power line.
However, in the "power line" shown in the above diagram, we then put a tiny capacitor in
series with the high-voltage line.
Then we increase the thickness of the capacitor's air-dielectric until dielectric is miles thick and
the current in the system is mostly composed of displacement current in the empty space
between the pair of widely-separated capacitor plates.  To transmit significant power,
step the voltage up to astronomical levels at one end, then step it back down at the other end.
Rather than using only a step-down transformer in the receiver, instead we use a hi-Q resonator,
and we allow the resonant voltage to rise to a huge value.  As a result, EM energy will be
"sucked" into the receiver.
We've been carrying around Nikola Tesla's power-receiver in our back pockets since the 1960s.
Also, in bygone decades, those old "regenerative" and "superregen" receivers were not what they seemed.
They were transmitting in order to receive, they were harnessing the same bizarre
"energy sucking" process.
Regeneration isn't just a fancy way to amplify a small signal, instead it increases
the incoming signal intercepted by a short antenna via some weird EM physics.
Do the designers of 90 years ago know something that modern scientists do not?
http://amasci.com/tesla/high_voltage3.html#tfiles
AlienGrey
Offline v8karlo
an interesting hypothesis but that's all it is, antenna more like earth ground is the biggest antenna there is.
So what your saying is you don't have a clue, in days gone by family's didn't have radio only the rich and scientists
Most family's had a piano and that was that! But perhaps that's your missing link, music, every thing is a musical note!
Don't want to say too much on here there are too many con artists and too much BS in a big way  :) ;) :D
